1034 Views 4 Replies Latest reply: Oct 23, 2011 2:14 PM by xxpizzapony RSS
xxpizzapony Just Startin' 6 posts since
Jun 12, 2011
Oct 22, 2011 12:24 PM
Better way to employ Pocket Pod's sounds for recording.
Hi guys,
I'm so excited with the sounds I've created on my pocket pod and I would to use these in some production of mine.
I've already a usb interface with 2 mic xlr/line/inst inputs: at the moment I'm connecting the direct out of pocket pod at the 2 inputs (used as Line) using an Y-cable like this.
Is this the right way to proceed?
The sounds recorded with this setup aren't so exciting as usual
Thanks for the help.
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Nake sure your Pocket Pod's output is set to feed Direct (to a P.A. / mixer) rather than to a guitar amp.
    To do that, follow these instructions in the manul (page 3.12):
    The Amp Out on your Pocket POD can be tuned for optimal performance with a variety of
    systems. By default, your Pocket POD expects to be plugged-in to the instrument input of a
    combo amp or head with an open-backed cabinet. If you want to plug in to something else,
    you’ll want to change the Cabinet Tuning Mode. To do this, do the following:
    • Press and hold the Save and Down buttons while plugging in the guitar input.
    • After startup, the display will show “Cab Select”.
    • The display will show current cabinet tuning selection.
    • Press the Up or Down buttons to change selection as follows:
    Use Mode... when Pocket POD is... ........& your speaker cabs are...
    A................ feeding a power amp input .....closed back (ideal for 4x12 cab)
    B ................feeding a power amp input..... open back (ideal for 1x12)
    C (default).... feeding an instrument input... open back (ideal for 1x12 or 2x12)
    D ................feeding an instrument input ....closed back (ideal for 4x12)
    Direct ..........feeding a recording device, mixer, live P.A., etc. .........not connected
    • Press Save to store the selection.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
