3488 Views 26 Replies Latest reply: Jan 19, 2012 9:13 AM by hamza4best RSS
hamza4best Just Startin' 58 posts since
May 21, 2011
Oct 23, 2011 3:24 AM
line 6 pod hd300 and spider 4 15w amp
Hi
i am thinking of getting a pod hd300 but i recently bought the spider 4 15w amp and after researching the pod i discovered that the amps like spider which have amp modelling don't work well with the pod.What i wanted to ask is that how does the pod sound through the spider if i only use the spider as a speaker by disabling the amp modelling.I know there are other threads about it in which they advice to push the tap button while you switch on the amp so it would disable the amp modelling but no one ever told how it sounds through the amp after doing it.And also i'm a huge muse fan andi like playing their songs so how is the pod for playing muse songs.Does the whammy have all the features availalbe in digitech whammy 4 like fx chorus,harmonizer? and i checked the website and it was written pod 300 has midi through usb.So if there is anyone who knows about achieving the  map of the problematique effect by writing a midi program in cubase and letting it control the whammy is it possible to do it in pod hd300?
thanks
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Oct 25, 2011 9:49 AM (in response to hamza4best)
    Re: RE: line 6 pod hd300 and spider 4 15w amp
    This is true. Both the Spider IV line of amplification and the POD HD devices utilize digital amp and effect modelling technology.
    Running a guitar signal through a POD HD300 and then outputting it into another modelling device may yield less than desired tonal results as the intention was to have the HD300 either go straight into a mixing console via the XLR DI or run the 1/4" outputs into a clean power amp (no digital modelling preamp section) and cabinet for amplification.
    There should be an mp3/CD input jack on your Spider IV 15. This is the closest to that scenario (bypassing the digital modelling, but utilizing the amp's power section and speaker).
    The Pitch Glide is modelled after the original Whammy pedal from the 80's/90's. The newer effects available on the Whammy 4 are not a part of that particular algorithm, no. You could simulate something similar in the Modulation effect models of the HD300.
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Nov 2, 2011 11:33 AM (in response to hamza4best)
    Hey hamza4best,
      As many of the users do, you may disable amp modeling by putting the amp into test mode by pressing and holding tap as you power the amp on. Keep in mind, the onboard amp controls including volume will be disabled, so the amp will run close to full volume.
      You mentioned the chorus/detune effect of the whammy, Perry was referencing the chorus effects located in the modulation section on the POD HD300. The POD HD300 also features the smart harmony effect which can reproduce the harmonizer modes of the whammy.
      As for the MIDI, when adjusting most POD HD controls, MIDI CC messages are sent to the POD HD USB MIDI Out port, Channel 1. It is possible to utilize the USB MIDI port to route this MIDI data to MIDI or DAW applications if desired. Further, many POD HD parameters can also be controlled remotely by receiving MIDI control messages on its USB MIDI In port, Channel 1.
        • SSstormtrooper Just Startin' 94 posts since
          Jan 19, 2011
          Nov 11, 2011 3:39 AM (in response to hamza4best)
          Truthfully I wouldn't waste my time buying the spider iv 15 watt if you already have an HD300.The little amp is made for bedroom practice or small band practice type scenarios.It will never really sound all that good no matter what.
          You would be much better off buying a used real tube amp that has a minimum of 2x10's.They can be heavy but are well worth it.Also you could look at buying a seperate power amp/speaker cabinet combination which also would produce killer sound.
          It's all about moving air really.It's like comparing the roar of an elephant to the squeak of a mouse.I own the Spider iv 15 watt and SpiderValve mkii HD100 so I'm familiar with their capabilites.To me the speaker in the Spider iv 15 watt is comparable to what you'd get in a 10 dollar flea-market transistor radio,seriously.
          Some solid state amps are okay like the Roland JC120 or JC60.It all depends on what you want to spend and if you care about buying new or used but you need some power and larger speakers to get you a good sound.Tube amps are heavy and need some maintenance once in awhile but are the best bar none.
          EDIT: Sorry I hadn't seen that you already own the spider iv.Same still applies lol,keep the little amp for quick turn on solid state practice but you'll need a bigger/better amp at some point if you want really good sound.
              Jan 19, 2011
              Nov 11, 2011 10:01 AM (in response to hamza4best)
              Well it should sound basically as good as the sound you're getting out of your amp now.It will sound good at bedroom volumes and such but not at gig or full band jam levels.Then again if your friends/band has a P.A. you can hook your amp to it or your HD 300 or both if you wanted so I wouldn't be disuaded by me into not buying the HD300.I'm just saying the HD300 will sound a heck of a lot better through a big amp or P.A.
              One other thing is you can always hook up the HD300 to good quality computer/stereo monitors or a good home theater system as well if you don't plan on buying any other amps right away.
                  Jan 19, 2011
                  Jan 16, 2012 2:41 PM (in response to hamza4best)
                  Okay dude I'm going to be blunt here.The Spider iv 15 watt is a toy,a small cheesy jack of all trades digital solid state transistor radio with some snazzy computer generated effects built in.It is what it is,a tiny practice amp,with a super cheap speaker and weak power handling capabilities.
                  Putting it in a neutral state still doesn't mean much,it's like putting perfume on a pig.
                  You want something in a similar size but costs a bit more but sounds great  go buy a Blackstar HT5-R.It has a way better speaker,built in effects loop,Emulated output,Jacks for an external cab,pad switch to adjust line levels to accept fx pedalboards or pedals -10db or +4db.It is tube driven a cranks damn loud(for a bedroom/practice amp).
                  Or go bigger,buy a Blackstar Studio20 or Club40 etc.Or a Line 6 DT50 or SpiderValve Mkii 112 or 212 that have Celestion Vintage30's inside.You get what you pay for and a Spider iv 15 watt will always be a toy.I know, I bought one when I was working out of town to play in the hotel.
                  I thought we had a discussion before about playing through a bookshelf stereo system.That is what it is also.I have a very high end home theatre system and sometimes I plug my Boss GT-10 into it via the s/pdif out and it sounds awesome.
                  Likewise your HD500 would sound great through a killer stereo also,because it is FR/FR(Full range/Flat response).Meaning that the speakers have a tweeter and hit all the highs and lows and such and don't have a pre-amp similar to a guitar amp ergo the flat response part of the equation.Some dudes run their GT-10's or HD500's into keyboard amps and really like the results.
                  I plug my different multi-effects boards into an array of different amps(Line 6,Blackstar,Ampeg,Mesa-Boogie...all tube amps BTW) and they all sound awesome.The Spider iv 15 watt will never sound good with external devices no matter what you do,it's reality.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
