1105 Views 8 Replies Latest reply: Nov 15, 2011 11:30 PM by maes2ro RSS
maes2ro Just Startin' 13 posts since
Dec 29, 2007
Nov 1, 2011 2:40 PM
Variax Bass volume, continued
Hi. Apologies to both Perry and Tony for the lack of response to their posts, I have not had a chance to log in for a while.
On the subject of the firmware update:
The Variax appears in the list of devices to connect to, however after connection, there is no reference to it in the device tree. Is this perhaps a registration issue of some sort where the Monkey does not recognise the Bass as a valid item? The serial number on the headstock is not alphanumeric like the device registration page offers, so maybe there is a problem there?
To make sure that I am working throught the procedures properly I have just attempted the string calibration:
I powered the guitar from the floor box to keep the pod out the equation, and the Variax went into calibration mode OK. I then monitored the output levels using the bar graph on my Creative labs recording software.
Before changing anything, the D & G strings were about 3 x the level of the A, and 4 x the level of the E.
I could not increase the level of the lower strings to match the higher strings, so I had to reduce the level of the D & G to meet the E & A, unfortunately there was still not enough adjustment to get down that far. The balance is still not great but is better, sadly the bass is now even quieter!
I will log in more frequently to make sure that I do not miss any new ideas.
Best Regards
Stirling
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Nov 3, 2011 2:06 PM (in response to maes2ro)
    RE: Variax Bass volume, continued
    maes2ro,
      The registration has no bearing on updating the flash memory in Monkey.  Hitting remind me later skips any registration bumps.  IF the Bass is not being recognized by Line 6 Monkey, that's a different story.  Which interface are you using?
      Please be sure to remove any batteries if you are powering with the power supply.
      If you are unable to sort it by re-installing the flash memory, it will need to go to an authorized service center:
      http://line6.com/service_centers/
      Regards,
      Line6Hugo
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Nov 4, 2011 10:34 AM (in response to maes2ro)
    The battery (disconnect it if you decide to use an XPS power supply) is more of a good practice suggestion from us. That's all, really.
    Dec 26, 2007
    Nov 8, 2011 11:47 AM (in response to maes2ro)
    Re: RE: Variax Bass volume, continued
    Just to clarify, none of the Variax guitar/basses have ESN numbers; that is not a clue (just making sure you're aware of this).
    However, if you're not seeing the Flash Memory component in Monkey's "Update" screen, this tells us you have a connection problem to the bass. Unfortunately it's sounding like a hardware issue that a repair tech will need to investigate at this point...
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Nov 15, 2011 4:57 PM (in response to maes2ro)
    If you are still having trouble with the Bass being recognized, then I would suggest that you have a Service Tech assess the bass for you. To locate a Line 6 Service Center in your area, follow the link below:
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
