1164 Views 8 Replies Latest reply: Nov 3, 2011 12:58 PM by solidjiver RSS
brenttp Just Startin' 3 posts since
Sep 23, 2008
Nov 1, 2011 8:39 PM
James Tyler Variax and Alternate Tunings
I am on my 3rd JTV and have had the same problem on all. I had the JTV 69 twice and now the 59. They all sound terrible in the alternate tunning position. As many have said you can hear the unaltered tunning and the alternate tunning coming through at the same time.
My set up is the JTV through the 1/4 inch jack to the X3L to my PA. I hear the bad sounds with or without headphones. I have flashed up the latest firmware and reset the JTV multiple times.
Is this the way everyone's sounds? What can I do to make this work?
    Mar 26, 2007
    Nov 2, 2011 1:24 AM (in response to brenttp)
    Re: James Tyler Variax and Alternate Tunings
    Hi
    When you use the 1/4" output from the guitar you should only hear the magnetic pickups or the models but not both at the same time.   This is not the way either of my two JTVs sound (a 59 and an 89). when running from the 1/4" output.
    Obviously you do have to have the amplification system loud enough to drown out the acoustic sound of the strings themselves - and working quietly at typical transistor radio levels with open backed headphones may cause the natural acoustic level to interfere with what the amp or headphones are putting out.
    I would recommend that you use a VDI cable from your guitar to the X3 Live as this will correctly interpret the audio coming from the guitar as well as providing a power source for the guitar independent of its internal battery.
    On the X3 Live you need to have the latest firmware installed.  This not only recognises the old Variax input, but it also recognises Variax Ch1 and Variax Ch2 from a JTV like the POD HD500 and POD HD Pro do.
    Nick
    • edstar1960 Iknowathingortwo 712 posts since
      May 25, 2010
      Nov 2, 2011 5:48 AM (in response to Nick_Mattocks)
      +1
      As Nick says - the 1/4" should only give you the mags OR the models (depending on whether you have the modelling knob pushed down - ie:switched on and illuminated).  The natural acoustic sound of the strings is surprisingly loud, and if you are playing at low volume levels they can easily be heard even through headphones and give the impression they are coming through the X3L/amp, so you have to make sure you are loud enough to cover that or that your headphones have closed backs and are loud enough to cover external noise.
      One way to prove whether it is just the natural string sounds causing the interference is to record the output from your X3L direct out into a PC or digital recorder. If it is working correctly you should only hear the altered tuning when you play back the recording. If it is faulty then you will still hear the altered tuning and the standard strings.
      NB:  Ensure that you set the INPUT selection on your X3L to GUITAR only. I think the default is Variax + Guitar + Aux - which should not make a difference if nothing else is connected to the X3L - but just to be sure you are only getting the 1/4" signal choose just the GUITAR input and use that input on the X3L.
      If you can record the JTV sounding both the standard tuning and the altered tuning via the 1/4" jack whilst the MODEL switch is on, then it is definitely faulty and Line6 will repair it for you.  You can provide them with the MP3 recording as evidence and contact Line6 to arrange for repair.
      Hopefully you will find that it is just the natural acoustic strings causing your problem and that your JTV is working fine.
      Good luck.
      Best Regards
      Eddie
  • laelamiles Just Startin' 377 posts since
    Dec 7, 2010
    Nov 2, 2011 10:49 AM (in response to brenttp)
    There is some bug on JTV that causes this.  I don't know if it's hardware or software issue.
    A few people reported success in reflashing or resetting.
    That didn't work for me at first.  What seemed to work is flashing down to an older firmware.  Then the double notes issue went away.  When I flashed back up to the latest version, the guitar stayed fixed.
    Again, I still don't know if this is a hardware issue or software because in theory reflashing should have fixed it if was really software.
        Dec 7, 2010
        Nov 2, 2011 9:54 PM (in response to brenttp)
        Flash to the highest version first (1.71?)
        If that doesn't fix it, then flash to a lower version (1.70?)... I think the same UI gives you the option of which version firmware to restore.
        I was really banging my head over this too, but believe it or not, flashing down (then back up) fixed it.
        Edit: Check here if you need to manually download the firmwares: http://line6.com/software/index.html
          • stevekc Just Startin' 114 posts since
            Feb 7, 2007
            Nov 3, 2011 12:21 PM (in response to brenttp)
            I suggest what you are hearing is the acoustical energy of your un amplified vibrating strings, conflicting with the Alt tuned version coming out of your guitar amp.
            brenttp wrote:
            Based on the above I recorded this into Garage Band and no double notes
            That answers your question.
            again
            Solution - turn the amp up louder!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
