2455 Views 15 Replies Latest reply: Dec 14, 2011 10:13 AM by gnfreire RSS
allnatural Just Startin' 144 posts since
Sep 23, 2010
Nov 3, 2011 11:30 PM
POD HD PRO?!?!
Wow right as im looking online at axe fx ultra on ebay since the axe fx2 is out. i found the new line 6 pod hd pro.. i am soooo excited about this!! the only thing i wanna know is if it has a lag or delay/sound gap when changing channels like the spider valve does. anyone have experience with this unit? if the pod hd pro has more cpu power im seriously buying this thing right now haha
    • Rowbi Expert Line 6 User 7,745 posts since
      Nov 25, 2006
      Nov 4, 2011 1:47 AM (in response to allnatural)
      Re: POD HD PRO?!?!
      the preset change is very fast, so you should have no issues with any delays with patch change.  I don't notice any delay at all.
      there is a free editor called POD HD Pro edit.
      I hope this helps
      Rowbi
      Mar 26, 2007
      Nov 4, 2011 1:55 AM (in response to allnatural)
      Re: POD HD PRO?!?!
      Hi jonnytrip
      Yes indeed, there is a new POD HD Pro unit available.
      I have one here.  In my experience it doesn't exhibit a significant delay between patch changes.   However neither do my Spider Valve MkI or MkII amps - and I know some apparently do.
      Any device that uses a system of stored patches which recall amp modelling and FX settings is bound by the nature of the physics involved to have some latency when changing between patches.  It is unavoidable and the best you can hope for is ultra low latency whereby any lag is unnoticeable.
      I don't notice any delay with the POD HD desktop, POD HD500 or POD HD Pro.  However I always tend to change patches between songs mainly or on the beat within a song if I have to make a change.  I don't tend to leave a note or chord hanging whilst I make a patch change.  If I were to do so then I could expect some evidence to come through that I'd made a patch change in the form of a change in tone more than anything but possibly an almost imperceptible gap.
      Some devices like the POD X3 Live/POD X3 Pro have a feature called 'delay trails' which are active over a patch change and this helps cover any tiny gaps or clicks caused by chaging the patch.  Unfortunately at present the POD HD desktop, HD500 and HD Pro only support Delay Trails when switching between two signal chains within a single patch.
      I personally don't notice any gaps and therefore I don't have a problem, however some people might view it differently depending on how they need to use a POD HD desktop, HD500 or HD Pro.  These three devices are siblings and the basic operation, amp modelling and FX modelling is the same.  Whilst not officially supported by Line 6 patches created on any one of the three will generally work straight away if dropped into the editor for one of the other devices.  Because they are all so closely related, you can test for yourself whether or not the HD Pro is likely to do what you need it to by testing the latency in patch switching on any one of them at your local Line 6 store, so before buying a POD HD Pro, I would strongly suggest that you check this feature out for yourself.
      You can always use an external delay pedal in the POD HD500/HD Pro's FX loop to manage delay trails if latency is a problem for you.
      Delay trails might be something Line 6 could include as a feature in a future firmware update, but I have not seen or heard anything to indicate they will do this. However, Line 6 do not normally publicly discuss their plans for new or existing products, so we will have to wait and see
      in the meantime you could submit a feature request directly to the Product Development team here: http://line6.com/company/contact/productfeedback/
      The POD HD desktop, HD500 and HD Pro do have a better spec DSP than the Spider Valve.  They all share the same DSP chipset.
      The POD HD Pro is currently still using the first firmware release as it was only released in September.  Past experience with Line 6 has often led to there being a firmware update for current products any time after release and these firmware updates may offer both bug fixes and additional features.  I can't say if or when a firmware update for the POD HD Pro or any of the other two devices I've mentioned might or might not be due.
      Yes there is an editor for the POD HD Pro.  It's called POD HD Pro Edit and like all other Line 6 editing programs it's a free download.
      I think the POD HD Pro along with its siblings has a lot of potential as it stands and possibly a lot more up its sleeve depending on exactly what Line 6 have planned.
      Nick
  • spikey Just Startin' 378 posts since
    Feb 1, 2007
    Nov 4, 2011 2:48 PM (in response to allnatural)
    Re: POD HD PRO?!?!
    Never Owned a Spider Valve, but I do have the HD Pro and am loving it's tone. Im using and older FBV Long Board with it,  and most (not all yet) of the buttons on it can be set in the software editor to work with the HD pro.
    Docs on using this Foorboard with the HD Pro are in the HD Pro advanced guide if u cant find any info elsewhere...
      Mar 26, 2007
      Nov 6, 2011 12:26 PM (in response to allnatural)
      Re: POD HD PRO?!?!
      Hi jonnytrip
      What I actually said above regarding patch switching relating to the POD HD Pro was this:
      With respect I did not mention ZERO latency or ZERO lag in my reply to you here.  There was no BS in my reply in any way shape or form.  I spelled it out very clearly.  I don't notice any perceptible latency.  If I did I'd say so.  I did take great care to pont out that the best you can hope for is ultra low latency switching.  I also pointed out how and when I tend to switch between presets AND that if I were to leave a note or chord hanging during a patch change I could expect some evidence to come through.
      As far as the Spider Valve MkII goes - again NO BS there either.  MY SV MKII does not exhibit a noticeable gap when I change between patches.  Maybe yours does.  I've never disputed that some SV MkII amps might display this characteristic.  Mine doesn't. Period.  From what I recall about the debate over that problem over in the Spider Valve forum, some users said they had a problem and others said they didn't have a problem.    If my SV MkII did display this problem and it was a problem to me I would have said so.
      Your mileage clearly varies from mine with your Spider Valve MkII, but is your experience any more or less valid than mine.  Have I ever suggested your experience and what you said about your SV MkiII's patch switching latency was BS or that you're being too demanding in your requirements?  No I haven't
      Your mileage may also vary from mine in relation to the POD HD Pro when you get to try one, so really there's only one way you can satisfy yourself as to whether it will meet your requirements and that is to try one for yourself and based on what you find you can decide whether it's for you or it's not for you
      I can only tell you with any degree of certainty what my own experiences are with my own gear - the same as anyone else can do - and that's all I ever try to do
      Nick
          Mar 26, 2007
          Nov 7, 2011 12:11 AM (in response to allnatural)
          Re: POD HD PRO?!?!
          No worries.
          I can't really tell you whether the HD Pro will cover your needs in terms of patch switching latency.  As I said there is bound to be some latency and if you leave a note ringing there is almost certainly going to be a very slight gap - i don't know of any modeller where this doesn't happen.  Delay trails between patches would help cover any areas of silence however small, but unfortunately the HD500/Bean/Pro don't have this functionality.  They all have the same core componenents so the latency between patches is going to be the same on all three.  You really need to try one of the three to get an idea of whether latency is likely to be an issue for you as only you will know whether or not you can live with it.  We all use our gear differently so whilst my Spider Valve and PODs don't present me with any latency issues that doesn't mean that you won't experience issues because a) your phyical devices will be different and; b) your requirements will  be a little different.
          FWIW I think the POD HD Pro is going to mature into something very cool over time   But don't let the excitement take precedence over the main things you need it to do as it may not be a perfect fit - these things rarely are.
          Nick
        • litesnsirens Iknowathingortwo 649 posts since
          Mar 20, 2010
          Dec 13, 2011 1:33 PM (in response to allnatural)
          Re: POD HD PRO?!?!
          One reason I hated using modelers in the past (besides the fact that they sounded like crap) was the latency between patches.  However with the POD HD500 I don't notice any latency switching between patches.  That doesn't mean there isn't any, it's just imperceptible to me.  This includes changing patches for soloing and back to rhythm, it "feels" instantaneous to me.  As Nick mentioned there probably is theoretically some latency.
  • Zap13 Just Startin' 2 posts since
    Nov 7, 2009
    Jan 23, 2012 11:44 AM (in response to allnatural)
    Re: POD HD PRO?!?!
    I am thinking of getting either the POD HD Pro or the Eleven Rack by Avid to take to gigs. Does anyone know which one is better?   And I notice there are far fewer amps in the HD Pro than in The previous X3... is there more amps coming in future firmware releases?
    And finally, I have an FBV shortboard that went with my X3 but I sold my X3... will that same shortboard work with the Pod HD Pro or do i need the FBV 2 for that?  I kept the shortboard assuming i would get an HD pro... but then I was led in the direction of eleven rack... and there are all these amazing deals on them on ebay.... so I am very indecisive and have no idea what to do.
  • gnfreire Just Startin' 54 posts since
    Mar 28, 2007
    Dec 13, 2011 2:10 PM (in response to allnatural)
    Re: POD HD PRO?!?!
    thanks for the comments nick mattocks and rowbi. but you guys are also the guys that told me you notice ZERO channel switch lag on the spidervalve... which was BS D:
    Yes, they're full of BS for shure... It happened to me too in a recent post. Be aware...
    • meambobbo Iknowathingortwo 1,702 posts since
      Dec 13, 2007
      Dec 13, 2011 6:30 PM (in response to gnfreire)
      Re: POD HD PRO?!?!
      i'd post a link of whatever accusation you're making or i'm inclined you're the one full of BS.  Rowbi and Nick are two of the most helpful, if not THE most helpful, people in this forum.
    Dec 13, 2007
    Dec 13, 2011 6:28 PM (in response to allnatural)
    Re: POD HD PRO?!?!
    i would say the dropout between patch changes is certainly perceptible, but still pretty darn brief and by no means any kind of dealbreaker.
    The only way around a brief dropout for a digital device as such, would be to have both the patch you're changing from and the patch you're switching to be functional at the same time during a transitionary period where the tone is cross-faded from one to the other.  This means any single patch could only use half of the available DSP.  I think most users would prefer that patches use all available DSP.  Thus for changes the current patch is unloaded, then the new patch loaded, meaning there is a necessary dropout during a patch change.
      Nov 25, 2006
      Dec 14, 2011 6:17 AM (in response to meambobbo)
      Re: POD HD PRO?!?!
      Hi Meambobbo,
      that's a very good explanation of how it works.  there's no way around that with DSP and in some tube amps where they're switching to different tubes in the signal path.
      Here's an interesting article about Marshall amp's switching delay being around 50ms.  there's also an interview around on the internet that I heard a few weeks ago where Santiago (one of the senior Marshall designers) explains that the slight delay on some of their amps when switching is to avoid a loud pop.  the JVM410H is fast switching but just audible... but the new Joe Satriani 410H has a built in noise gate, so they used that to mute the pop, meaning they could get a faster channel change.
      Cheers
      Rowbi
    Mar 28, 2007
    Dec 14, 2011 10:13 AM (in response to allnatural)
    Re: POD HD PRO?!?!
    i dont have any POD HD PRO yet but what i can say for shure since it shares the same architecture of both HD500/400/300 is that if you use any of these units conected to any DT amp you'll notice a drastic and scary boost of signal when changing preset patches from class A/B to class A and not vice versa. This is just for an half second or something but it can be tricky and frustrating when you play live or in some demanding studio sessions. Again, this is not documented anywere in manuals and nobody around talks about this. Be aware of that.
