939 Views 18 Replies Latest reply: Nov 28, 2011 1:03 PM by jcurry RSS
jcurry Just Startin' 28 posts since
Jul 12, 2011
Nov 6, 2011 3:06 PM
DT-50 Digital Noise.
The DT-50 212 is my first tube amp, so maybe this is normal, I don't know. I've had this amp for about 3 days. I played it for about 2 hours today and started to notice this periodic digital noise coming from the amp. To troubleshoot I started by disconnecting the guitar, unplugging the L6 connection that is plugged into an HD500, and finally unplugging everything else that was going to the same power strip.
So, nothing is plugged into it, and there are no other devices plugged into the same power strip. it's quiet for about 5-10 seconds and then theres about 3-4 seconds of what sounds like digital noise. it's quiet, but easily heard when practicing by yourself in an otherwise quiet room. The master volume control has no effect on how quiet or loud the noise is. The amp was also very hot, so I put it in standby mode. There's no noise when its in standby mode.
After leaving it in standby for about 20 minutes I turned it back on and I didn't hear anything. The only other thing I can remember about it was that it was in 'low power' mode for the 2 hours I was using it. Can that cause issues if used for too long? Of course, there's always the possibility that there's something around here causing interference that the amp is picking up.
Any suggestions would be appreciated. Thanks.
  • bartpuglise Just Startin' 104 posts since
    Mar 16, 2006
    Nov 7, 2011 3:29 AM (in response to jcurry)
    Re: DT-50 Digital Noise.
    It's quite possible that it's the 12ax7's in your amp I had my DT50 head for a month or so and started getting noise. Replacing the tubes solved that issue. Make sure your firmware is all updated as well and get yourself a DMX XLR cable for your L6 link I had a real strange feedback sound that drove me nuts and after replacing cable it went bye bye. Best of luck with your DT once you spend some time with it you'll appreciate it!
        Mar 16, 2006
        Nov 7, 2011 8:18 AM (in response to jcurry)
        Yes the aes/ebu cable is a Data cable which is what a DMX cable is as well. You may be getting noise off of your patches. Try plugging directly into the amp. I ordered tubes from www.tubedepot.com there is a lot to choose from. I have used Sovtek in the past so that's what I put in my DT50. Also the pre-amp tubes need not be biased. If you search the threads you'll find a lot of info on biasing. Every tube amp I've owned had some noise but nothing annoying. Rock on!!!
            • ethyl80 Just Startin' 150 posts since
              Jan 27, 2007
              Nov 7, 2011 12:11 PM (in response to jcurry)
              was your cell phone near it when you were playing?
    Mar 16, 2006
    Nov 7, 2011 2:18 PM (in response to jcurry)
    That swoosh sound is exactly what my DT50 head was making! I replaced the 12ax7's and that sound went away! I then replaced the power tubes. The only tubes that need biasing are the POWER TUBES and the bias setting is 35 milli-volts
        Mar 16, 2006
        Nov 7, 2011 3:39 PM (in response to jcurry)
        Yeah no s**t that's my only gripe about the amp also the telex is thin and there are no corner guards but...... Hands down best sounding rig I've ever owned. I also run a DRZ attenuator that really makes it sound bad *** but replacing tubes is a small price to pay I don't think a cell phone or wireless laptop is the issue. Well best of luck make sure you run per-amp models on your HD500 I think they sound much better!
      Mar 26, 2007
      Nov 7, 2011 4:01 PM (in response to bartpuglise)
      The bias setting for the DT-50 is actually 36mV
  • snooze12 Just Startin' 30 posts since
    Dec 8, 2009
    Nov 12, 2011 8:48 AM (in response to jcurry)
    Do the DT25 is less noisy than the DT50?
