1219 Views 12 Replies Latest reply: Dec 27, 2011 6:36 AM by RicW RSS
markcsomers Just Startin' 55 posts since
Apr 2, 2007
Nov 15, 2011 8:42 AM
30 pin extender needed when using Mobile In?
I am looking forward to getting my Mobile In device that I ordered yesterday.
Two questions:
1.  Will I need a 30 pin extender/adapter in order to plug in the device if my iphone is in a case?
2.  Will using an extender cause any problems (ie: latency) with using the program/device?
It looks from photos and videos that there is no space between the top of the Mobile In and the ipad/iphone when the device is plugged in.  Therefore, one will need to either use a 30 pin extender/adapter OR remove the iphone from the case when wanting to use the Mobile In device.
Thanks for the help!
  • Icewind Just Startin' 230 posts since
    Jul 7, 2008
    Nov 15, 2011 9:54 AM (in response to markcsomers)
    Re: 30 pin extender needed when using Mobile In?
    I can't answer #2, but the answer to #1 is almost certainly yes.  Any case that obstructs the bottom of your device will make it difficult--if not impossible--to seat the Mobile In.
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Nov 16, 2011 4:48 PM (in response to markcsomers)
    Hey markcsomers,
    1: It depends on the case, however most cases should accomodate the Mobile In just fine. The connection is the size of the standard 30 pin connection. Where you could encounter a problem is if your case is rather thick around the dock connection. The Mobile In adpator fits just about flush against the bottom portion of the iDevice.
    2: We have not seen any reporting cases of a extender causing problems, although as I mentioned above most cases will accomdate the Mobile In just fine without the need for a 30-pin dock extension cable.
  • squeegy Just Startin' 34 posts since
    Apr 7, 2007
    Nov 25, 2011 5:59 PM (in response to markcsomers)
    I have the Apple bumper case and I do not need an extender.  I do have one that I use for a Bose dock and I tried it on the Mobile In.  The DockStubZ extender by CableJive worked fine if you did have a case with a thick bottom.  absolutely no change in sound or latency with it on.
    • JeffValenta Just Startin' 35 posts since
      Jan 28, 2007
      Nov 26, 2011 12:04 AM (in response to squeegy)
      that sounds like just what I need because the bottom of my case is too thick.
      I notice that the DocStubZ extender has a mini-USB for charging while using the Mobile In.
      I just want to know if charging it at the same time as using it with Mobile POD will damage the Mobile In?
      thanks!
      Jeff
        Apr 7, 2007
        Nov 26, 2011 8:19 AM (in response to JeffValenta)
        I haven't had a chance to try it, but from info on cable jives web site, it is meant for when the dock you are connecting to can't supply power like those old fire wire docks.  my guess is that it woul d not hurt the mobile in hardware, but someone from line 6 might know more.  one thing I found when connecting mobile to your iPhone disrupts the iPhone from finding any network 3G or wifi.  it is best to go into airplane mode to save battery as it will continuely search for a network the whole time you are jamming.
          Jan 28, 2007
          Dec 5, 2011 8:20 AM (in response to squeegy)
          Mobile In does work great as a digital in for certain programs. BUT, it won't support using any sort of 30-pin pass through extender, powered or unpowered. I've already spent over $50 in different extenders because I don't like the precarious way the Mobile In hangs off of the iPad. I intend to use the Mobile In and iPad for live performance as well. When plugging in any extender, then the Mobile In to the extender I always get "USB device not supported" message. Line6 needs to fix that.
  • rperretta Just Startin' 4 posts since
    May 6, 2007
    Dec 10, 2011 10:34 AM (in response to markcsomers)
    Bad news  - I just got my Mobile In, hooked it up to my iPad2 and the connectioin is so intermittent as to be unuasable.  THe connector doesn't click in at all, even when the iPad2 is out of the case.  If you hold it just right with both hands, click your heels an dsay there's no place like home....  Well you know the story.  Looks like RMA time...
    I RTFM'd just in case. No luck.
    Anybody else have this problem?  I'm a long time Project Manager in the electronics Industry and I can't imagine that the product would have made it out of development without adequate design review in mechanical engineering and component qualofication. Did I get the bad one?  Would an extender fix it? - Less hassle than RMA. I just want to make music.
    I'm thinking about Jeff's posting above as well. Even if it did work, it seems preacious. They should have used a cable.  If it was my project, that design wouldn't have left the factory. I've been a LIne 6 customer since AX212 but I may have to look elswhere on this one. Even the best stumble. Say it ain't so Line 6!
      Jan 28, 2007
      Dec 13, 2011 9:14 AM (in response to rperretta)
      I'm pretty convinced Line6 knew ahead of time what would work and what wouldn't. If they had been upfront with that, it would have saved me over $50 and much frustration trying to improve the usefulness of the Mobile In.
      IMHO I think they wanted to be first to market (or largest userbase to market) AND do it before the Holidays.
      That being said, I did use my iPad and Mobile In/Mobile Pod for a gig over the weekend and people were blown away!
      I bought a dremel tool and made the 30-pin opening bigger on my plastic x-clip on a mic stand. Worked great.
      I love the technology, and I think with a bit more effort, Line6 could hit a homerun with this concept.
      I'd have to believe that the processor in the iDevices is capable of handling the HD sounds/fx.
  • RicW Just Startin' 11 posts since
    Jan 24, 2007
    Dec 21, 2011 6:47 AM (in response to markcsomers)
    I bought this dock extender and it works fine for both ipad 2 and iphone 4s.
    http://www.amazon.co.uk/gp/product/B004E7OOCK
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
