524 Views 6 Replies Latest reply: Nov 19, 2011 8:26 AM by Granttye RSS
Granttye Just Startin' 11 posts since
Nov 18, 2011
Nov 18, 2011 2:18 PM
JTV 69 Model output levels?
My JTV 69's output for the models is much higher than the magnetic pickups...much higher than the mags on any of my guitars. This makes for too much adjustment when trying to switch instruments live.  Also,  I'm hearing a little distortion in the models...I'm hoping lowering the levels may solve these problems. Can this be done with the Workbench?
I'm also noticing noise when using the trem with models (cleaner quiet tones)...knocking and rubbing sounds, wouldn't cut it if I was trying to use this for a session. Any one experiencing these issues?
  • daferalo Iknowathingortwo 270 posts since
    Apr 12, 2010
    Nov 19, 2011 7:19 AM (in response to Granttye)
    Re: JTV 69 Model output levels?
    Hello Granttye,
    I have a jtv 59, but I guess it should work quite the same for your jtv 69 and you might want to take it into account.
    1) If you have a volume difference between magnetic pickups and guitar models on your jtv 69, it is due to the magnetic pickups height, if they are too far from the strings then the output volume level of them would be low. Anyway, remember that output volume level of the "real" guitars that are being modeled is not the same if you want to make comparison among them.
    2) You can adjust the output volume level of the guitar model through workbench editor, there is a "volume" option you can set to your taste there.
    Best Regards,
    Daf
        Apr 12, 2010
        Nov 19, 2011 8:18 AM (in response to Granttye)
        Yeap, the "volume" option on workbech editor software adjusts the overall output volume level of the guitar model being selected (it is a trim level), but it does not affect all models, just the one you are adjusting. You have also options for adjusting the output level of modeled pickups, they act as the pickup height would act. Also, you have an option at "Editor" menu which calls "string volume setup", which could work for a general adjustment of the output volume level for all the guitar models
            Apr 12, 2010
            Nov 19, 2011 8:24 AM (in response to Granttye)
            Yeap Granttye, the "string volume level" is located at Editor menu, it works as a general adjustment of the output level for all guitar models. I tried today because I did not need to do so in the past. It works quite well, although I think it affects the sustain a little, I am not very sure about it but it is my perception.
            Best Regards,
            Daf.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
