675 Views 3 Replies Latest reply: Nov 29, 2011 10:38 AM by Line6Don RSS
jhar404 Just Startin' 1 posts since
Nov 11, 2011
Nov 18, 2011 6:12 PM
Bass pod Xt live and Line 6 edit
When I try to load my pedal in Line 6 edit program my pedal freezes when its about 90% loaded. The a window will pop up saying that the bass pod has stopped responding
any way to fix this?
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Nov 21, 2011 10:05 AM (in response to jhar404)
    Re: Bass pod Xt live and Line 6 edit
    Are you using the most recent drivers, Line6 Edit and Java?
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Nov 22, 2011 11:03 AM (in response to jhar404)
    RE: Bass pod Xt live and Line 6 edit
    Hey jhar404,
      Download and install the latest drivers for your operating system:
      Windows Drivers 4.2.4.9:
      http://line6.com/software/readeula.html?rid=4143
      MAC Drivers : 7.1.0
      http://line6.com/software/readeula.html?rid=4171
      Once the drivers are installed you will need to install the Line 6 Monkey application from the links below:
      Windows Line 6 Monkey 1.43:
      http://line6.com/getrelease?rid=4223
      MAC Line 6 Monkey 1.43:
      http://line6.com/getrelease?rid=4222
      Once Line 6 Monkey is installed, remove any additional unnecessary USB and firmware devices from your computer when troubleshooting this issue. Make sure to connect it directly to a USB port and not a USB hub, extension, or keyboard of any kind, preferably connect it to a USB port on the rear of computer. Try using additional USB cables and every USB port available until you are able to launch Line 6 Monkey and detect the device.
      After Launching Line 6 Monkey apply any updates that are available until you have a green check next to each component.
      I would then try again to launch the Line 6 Edit application. If you encounter the same problem once again, I would suggest to try connecting the Bass POD XT Live to another USB port on the computer, try again, if it crashed again, try another USB port until you have exhausted all available USB ports on your computer.
    Mar 14, 2011
    Nov 29, 2011 10:38 AM (in response to jhar404)
    Hey jhar404,
      This thread is being closed due to lack of response within 72 hours. If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
      http://line6.com/support/community/support/
      For more information about using the Online Technical Support System please review our FAQ at the link below:
      http://line6.com/support/docs/DOC-1451
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
