Nov 19, 2011 7:02 AM
stutter when changing patches
Like (0)
I fired up my HD500 for the first time last night (headphones only so far) and the amps and effects are a definite improvement over the X3. In addition to a couple things that I've mentioned in other threads, there is a "stutter" when changing patches. Like a triplet of hitting a cut switch on and off. Is that par for the course?
I wouldn't say it was normal, no. Are you simultaneously connected to your computer and POD HD500 Edit when this happens? i suspect you might be ![]()
Nick
Yes, I was. I was using hdedit to go through some patches quickly from customtone. So that's the culprit? I guess that makes sense.
HD500 Edit acts as a buffer and remembers your settings when you make a number of different patch edits. I think it is the most likely culprit here, but just double check that the HD500 doesn't stutter when you don't have it connected to your computer ![]()
Yep, that was it. Without being hooked up to my laptop, patch changes are normal.
