610 Views 10 Replies Latest reply: Nov 23, 2011 6:28 PM by sgallaga1 RSS
sgallaga1 Just Startin' 11 posts since
Nov 16, 2011
Nov 19, 2011 8:12 PM
POD HD in south korea getting a lot of humming sound when using a guitar
Hi
Im getting alot of hum and fuzz sound from my POD HD when my guitar is plugged in. It's most noticable on presets such as master of puppets and distortion effects etc.
I live on the 10th floor in a fairly new 20 storey apartment in south korea and am wondering if this is a grounding problem. The south korean  plug only has 2 pins with no third pin for grounding so Im wondering if buying an adaptor that has a ground pin would help reduce the hum.
The standard voltage in south korea is 220V with a frequency of 60hz. The standard plug used is a type C though type F (grounded plug) can be used.
http://users.telenet.be/worldstandards/electricity.htm
One thing i have noticed is that sometimes the hum is reduced when I place my hand on the guitar lead right where its plugged into the POD HD guitar input or on the power input to the unit.
I hope someone can shed some light on this.
Thanks
Stu
      Mar 26, 2007
      It sounds like a lack of a ground connection is causing your issue.  I don't believe it is a ground loop issue necessarily.
      Nick
    Jan 27, 2010
      It's possible that the pickups in the acoustic guitar could be an issue. Does the acoustic feedback easily with another processor or amplifier?
    Also, have you tried  a different guitar cable?
      Thanks,
      David
      Line 6 Customer Support
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
