464 Views 18 Replies Latest reply: Jan 27, 2012 3:49 PM by Line6david RSS
Brillemonster Just Startin' 19 posts since
Apr 12, 2008
Nov 29, 2011 11:09 AM
Constant static
Hello,
I am using a toneport GX (I own 2 of them), and I have the following problem:
When I am playing the guitar through POD farm or Gearbox, I have a constant static/white noise on the background.
I have tried:
- Different computers (both desktops and laptops (on a laptop there is a difference in the amount of static when the powerchord is attached (with powerchord the static is worse))
- Different cables
- Different guitars (all 4 of my guitars)
- Both toneports that I own
All the machines have Windows 7 64-bits running at this moment. But they all had the problem with the 32-bits version running.
I know I can use the noise-gate, but then there is no sustain in the guitar, wich I need very much in my music. And still the static is present in the background (and clearly to hear).
This problem occured after an installation of newer versions of gearbox/POD farm/drivers/etc (reinstallation of the machine, and installed the newest versions)
I really have to solve this problem, because one of the machines is going to be used in the rehearsel room for recordings of a Demo. And, understandable, we don't want to have the static on it.
Can you help me out?
(For the Line6 people: I allready had a support ticket for my laptop problem, but it dissapeared somehow, but that problem is not solved as well)
  • Line6david Line 6 Support 5,236 posts since
    Jan 27, 2010
    Nov 29, 2011 4:18 PM (in response to Brillemonster)
    Re: Constant static
    This issue could be related to a number of things. First check your connections.
    Have you tried connecting to different USB Ports?
    Are you using a USB hub?
    Make sure you have the latest drivers installed:
    http://line6.com/software/
    Then try the optimizations in our USB Troubleshooting Guide:
    http://line6.com/community/docs/DOC-4282
    Thanks,
    David
    Line 6 Customer Support
      • Line6Hugo Line 6 6,589 posts since
        Apr 8, 2007
        Dec 2, 2011 4:42 PM (in response to Brillemonster)
        Re: Constant static
        Is this a new problem, or has it always been there with these devices.  You're purchase 2 of our interfaces so it must have worked fine.  Also, can you please provide a recordin of this noise along with your playing so that we can hear how loud it is relative to your playing and compare with what we have here?
        Regards,
        Line6Hugo
            • Line6Don Line 6 Support 5,218 posts since
              Mar 14, 2011
              Dec 13, 2011 9:38 AM (in response to Brillemonster)
              Re: Constant static
              Hey Brillemonster,
              If the TonePorts were working correctly prior to upgrading your computers operating system, then the problem is somehow related to this upgrade. I would suggest that you apply all available Windows updates to both computers, as well as updating the drivers for all of the hardware components on the computer. Make sure to try each USB port on both computers to see if you receive any difference in the static from port to port.
              Recheck that you have the most current Line 6 drivers installed on both computers, GearBox comes bundled with older drivers, and if you install these drivers with GearBox there is a chance that your drivers became out dated.
              If you have also tried all the suggestions available on our USB Audio Troubleshooting doc without success I would suggest that you try it on a third computer to see what kind of results you have.
    Jan 27, 2010
    Dec 19, 2011 2:30 PM (in response to Brillemonster)
    Re: Constant static
    First, make sure your GX's output is not connected to the input of your computer's soundcard. This can cause all kinds of strange noise and issues.
    Static is usually related to a hardware conflict or under powered port. First, try EVERY port on the computer. See if one port seems to work better that another.
    Now for the hardware issue. Alot of times, in my experience video card drivers are the culprit. Try downloading the latest drivers from you cards manufacturer.
    Next what other video/audio devices are connected to your computer via USB or firewire? Does disconecting/disabling a device eliminate the issue? (webcams are especially notorious for causing issues)
    And finally run Windows update to make sure the issue is not related to an outdated OS:
    http://www.update.microsoft.com/windowsupdate/v6/thanks.aspx?ln=en&&thankspage=5
    Thanks,
    David
      • Line6Tony System Admin 1,820 posts since
        Jan 16, 2007
        Dec 22, 2011 12:51 PM (in response to Brillemonster)
        Re: Constant static
        Unfortunately, it sounds to me that the the TonePorts are both broken. You get the same noise on any computer with various OS installs. They both worked previously, so some change to your computer or possibly a surge from it is likely the root. It would be highly unlikely that both units failed on their own at the same time.
    Jan 27, 2010
    Jan 27, 2012 3:49 PM (in response to Brillemonster)
    Re: Constant static
    Hello. It has been at least 72 hours since we've heard from you. We're going to assume your question has been answered. If it has been answered, please award points to whoever was helpful and/or answered the question.
    In the event your issue has not been resolved, I created a support ticket for you so we can continue to communicate. Please respond to the ticket. Thanks!!
    Q: What is a support ticket?
    A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link to the ticket when a Line 6 Support Representative responds to it. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support. Also, in your account, click My Account, then click Support Tickets to view the support ticket. Here’s a shortcut: http://line6.com/account/tickets/view/.
    Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host, and also that your email account is receiving messages at all.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
