1569 Views 11 Replies Latest reply: Dec 10, 2011 3:17 PM by PerS RSS
PerS Just Startin' 17 posts since
Aug 16, 2007
Dec 2, 2011 3:27 PM
Buy a POD HD Pro or DT25...
Hi
I turn to you to  give me an advise... I have been struggling between buying a POD HD Pro as a replacement for my POD XT (have done an excellent job, bought one of the firs that came out and replaced my POD2...) or a DT25 witch I'm really impressed off the demos I've heard and the DT50 I tried. To this I should add that I have made myself a pedal board and I am really satisfied with. Started with as I wanted to try to see if the XT sounded different if I off loaded the boost/od/dist effects, and it did... different story, take that another time... but I plan to keep it if the on-bord pedals is not blowing me away... In other terms, It's the amp's I'm in for and some delay/reverb.  So my questions.
Start with the POD HD Pro :
- Have anyone tried it with pedals? Experience? Does it behave “as an amp”?
- Have anyone tried it into a tube amp (into the loop or an tube power amp)? Experience?
- Anyone run a Variax 500? Acoustic, through it to a PA and how did it sound (a clean patch without amp sim...or how)?
The DT25:
- There is a 12ax7 in there, is it for the input stage or is it for in phase in to the power stage?
- Have anyone tried it with pedals? Experience? Does it handle it as a “real tube amp”?
- When tried the DT50 I dialed in a crunch sound, really nice... I then tried it in “bedroom mode” just so see how it sounded. My experience it lost some of the dynamics and the bottom end. What is your experience with the DT25.
- I read somewhere that when changing power tubes I needed to take it to a shop to adjust the bias, is that true? No external way or instructions how (I have done it before on other amps...)?
I see the benefit off them both, but my finances does not cover both. In the future maybe... An advice to take me out off the confusion please.
//Per
      Mar 26, 2007
      Dec 3, 2011 1:09 AM (in response to PerS)
      Re: Buy a POD HD Pro or DT25...
      As Space says, it's a difficult call.   I would possibly look at the POD HD500 as a viable replacement for your POD XT given that the HD500 has Variax capability using VDI and comes ready as an all-in-one floor controller/processor which has the same capability as the POD HD Pro except in the area of i/o.
      With a POD HD Pro you will need some way of controlling it which could either be in the form of a third party MIDI controller or one of Line 6's FBV pedal boards (FBV Shortboard MkII recommended for full capability but MkII Express, MkI Express and Shortboard will work in as far as they are able to).
      The POD HD Pro is a very good rack mounted version in the POD HD/HD500/HD Pro family, but unless you particularly need the extra i/o options you may be able to save yourself some money towards purchasing a DT-25 sooner by opting for an HD500 instead.
      In UK terms typical pricing is as follows in GBP (from the Internet this morning)
      POD HD500 all-in-one solution = £409
      POD HD Pro @ £629 plus FBV Shortboard MkII @ £169 = total £798
      DT-25 combo = £620
      I don't know where you live or what the pricing structure is like there, but I would expect something similar.
      Nick
      • Sean_Clarke Just Startin' 65 posts since
        Jan 24, 2009
        Dec 3, 2011 1:31 AM (in response to Nick_Mattocks)
        +1
        I have the HD500 + DT25; if you can run  to it you get a great sounding Amp + your direct PA output.
        Just depends how much you relish that 'real' Amp sound...you need to go and hear it live.
        DT25 sounds great and has a PA output, for blues rock you may be able to live with the 4 HD Models- lets face it, its like having 4 different valve amps on stage! You could also 4CM your existing POD for effects. You will however be carrying some extra weight (its heavy!)
        All in all, I would go for just adding the HD500 to your set up, you are carrying no more than a pedal board and you have the most portable quality  'just plug in any PA' set up available
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Dec 2, 2011 3:59 PM (in response to PerS)
    That's a tough call...I have an HD Bean, DT50 112 and DT25 head & cab...I also have an HD400, but it isn't getting as much use these days...
    The amps....I love these amplifiers. I think they are fantastic and give some pretty amazing diversity of tone. I have a BCB 60 loaded with a bunch of stomps and a channel switch...I love using them this way as it is the way I came up. Seeing how you have pedalboard you like, I think a DT25 would be a great choice...If you have biased an amp before, you could likely do the DT25....the 12AX7 is the inverter...preamp is an HD modeler...
    The HD bean is a lot like the HDPro in terms of the models and FX being the same...IO is the difference...Anyway, I love the HD bean...Most often I am using the bean to the power amp in of the DT25 and the DT50 together...I have also run the HD Bean to my SV112s...I have a MK1 and MK2...That work quite well also...the amp modeling is a different world from the XT IMHO...An HD with a PA-amp will blow the doors off an XT in a FRFR system I think...XT always sounded really run that way, but never really felt right to me run that way...I have an XT bean and if I run that into my SVs, it feels good...I have used it direct as the XT bean used to be my spare and I have to run direct into the PA a few times...It would do the job and people listening to show liked the tone, I never liked the way that felt...
    I tend to lean toward recomending the HD Pro to you mainly because you have a Variax...It seems like a better fit at this point...You could always go to the DT amplifiers later on and I tend to think that the an HD POD might be a better place to start in your case...But you gotta mull that one over carefully...
      Mar 26, 2007
      Dec 3, 2011 4:47 AM (in response to PerS)
      Hi Per
      I did not think for one minute that you were at all rude   You asked some perfectly reasonable questions IMO.  Ask as many questions as you like.
      Personally - and this is just my take, I don't use any additional stomp boxes or pedals with the HD500 in my signal chain although I still have all my old Boss etc... FX.  The HD500 does enough for me on its own.  That might not be true for everybody of course, but it is for me
      It's your call ultimately of course, but a saving of nearly 50% of the cost of a POD HD Pro plus FBV Shortboard by buying a POD HD500 is a big consideration to me, especially if my ultimate goal is to own a DT-25 amplifier too as in buying the HD500 over the HD Pro + FBV I get to keep more than half what a DT-25 combo is going to cost me.
      I don't know what you have on your pedal board that you really couldn't get away without using if you had any of the POD HD, HD500 or HD Pro in your system.   That's not my call to make   In any event, the POD HD500 does have an FX loop so if there is anything particularly dear to your heart that you really cannot manage without, then you can include any additional pedals if you really need to - but yes I see that doing that would take up a little more floor space which is a disadvantage.
      I understand what you're getting at and intend no disrespect with my thoughts above.   I would highly recommend though that you find a stockist in your area which has both an HD500 and a DT-25 in stock that you can try out for a couple of hours in store with your Strat and Variax to see whether you can get near the sound you need.
      Nick
    • jyflorida Just Startin' 221 posts since
      Feb 13, 2007
      Dec 3, 2011 5:40 AM (in response to PerS)
      Hi Per,
      I've used numerous pedals in my HD500's FX loop before the amp models and for the most part I get outstanding results.  My current preferences are a Fulltone OCD and a Danelectro Transparent Overdrive.  I don't use anything else like delays, phasers, flangers, etc., since I get great results with those models in the Pod.  I run the HD500 into a DT50 112 with the L6 Link, but the results were great going into a PA also.  BTW, the DT50 by itself sounds great with pedals also.
      Jim
      Feb 13, 2007
      Dec 3, 2011 8:07 AM (in response to PerS)
      As far as "feel" when running into a PA or a DT, I won't go back to running direct to PA unless I have to.  The DT50 definitely adds an organic and more dynamic tone & feel to the overall sound, just the way a good tube amp should.  Very responsive to pick dynamics and guitar volume adjustments, even when using pedals in the loop.  The DT series will also let you run direct to PA from an XLR output jack on the amp itself so you can get the best of both worlds - the tubey goodness and the ability to run that goodness to the PA.
      Mar 26, 2007
      Dec 3, 2011 9:35 AM (in response to PerS)
      Hi Per
      To me there's no doubt that the POD HD500 paired with a DT-xx amp does provide the most natural sound if you are used to using a real amp.  Pushing the output from the POD HD, POD HD500 or POD HD Pro into a decent PA system also sounds great, but for me it's better to go to a real guitar amp - even if it's my Marshall JVM
      Going in to either my DT-50 or DT-25 works well if I need to go to PA as well because the cab emulated DI out on either DT amp does provide a very natural and accurate sound to PA based on what you hear from the DT amp's speaker.
      Nick
