775 Views 10 Replies Latest reply: Mar 25, 2012 12:47 AM by anglepod RSS
facemask Just Startin' 8 posts since
Mar 1, 2007
Dec 3, 2011 4:51 PM
Just got the POD HD500, beginner's help w/amp
just got the HD500 and im using it on a Marshall JCM 2000 TSL602. i am completely new to the POD and i can't seem to get a good sound out of my amp. i've got a clean sound on the amp and the bass/mid/treb all at 5, but the sound coming from the POD has too much trebel. i am trying to use the POD to control it, but just cant get a good sound. i know half my problem is me just not knowing much about the HD500 yet.
the other half is choosing an amp. i am trying to sell my Marshall and get a small non-combo amp. wondering what you all play with an HD500. if any of you happen to use a Marshall JCM, any suggstions on the settings to go with both on the amp and the POD? i know i just got to play around with it more and experiment, but figured i'd see what more experienced users have done with their setup.
  • THORNSZ Just Startin' 31 posts since
    Oct 17, 2011
    Dec 3, 2011 10:35 PM (in response to facemask)
    Re: Just got the POD HD500, beginner's help w/amp
    Additional Question:
       -i was pretty confused too in what should be the settings on my amp if i'm gonna apply the amp modeling... should all the settings suppossed to be in 12 O'clock?
  • hitchface Just Startin' 334 posts since
    Jul 1, 2007
    Dec 4, 2011 6:54 AM (in response to facemask)
    Consider the EQ controls on your amp to be a "global" EQ. Set them wherever you want, and only tweak the POD for simplicity.
    A unit like this is a tweaker's paradise. Be ready to twist knobs like a boss to get that sound you want. Don't be afraid of experimenting. It is YOUR sound, after all.
    And again, just set and forget the EQ on your amp. ONLY change the EQ settings on the POD so you have consistency from patch to patch. If you run out of adjustment on the POD and need more, then you can tweak the amp EQ and then adjust your other patches around it.
    • arislaf Iknowathingortwo 426 posts since
      Sep 8, 2010
      Dec 6, 2011 2:59 AM (in response to facemask)
      And in case you don't know, change the output setup from direct/studio to combo and stack.
  • Al_of_D Just Startin' 1 posts since
    Jan 19, 2010
    Jan 4, 2012 3:48 PM (in response to facemask)
    The amp you are using is a great wee amp... try running the pod through the effects loop and using the amp distortion it'll be better than the pods.
  • alexisltd Just Startin' 19 posts since
    Sep 17, 2010
    Mar 12, 2012 3:43 PM (in response to facemask)
    if your amp doesnt have fx loop you have to use the guitar input in yor amp....Opposite to general consensus 12 oclock ITS NOT flat or neutral...try this eq in your amp : bass 0,mids at max,treble 0 and fine tuning with the presence....put the pod HD output setting in combo poweramp...maybe you could experiment with the studio/direct setting too.
  • anglepod Just Startin' 172 posts since
    Mar 24, 2012
    Mar 25, 2012 12:47 AM (in response to facemask)
    For my personal opinion I do not think modelers work well or can do what they are designed to do feeding them to a guitar amp.
    I run my HD500 into a rackmount BBE phase correction maximizer and into a 2 channel (stereo) power amp which goes into a 4x12 split cabinet.
    Each and every model comes out with a fidelity you have to hear to believe. Imagine as an example a moderately different Fender Blackface or a Tweed on each side of the cab plus panning capability. Marvelous unit this HD. A real mad scientist lab.
    I have a killer tube amp half stack with a huge pedalboard. I am integrating some of my high end pedals but not using the tube head.
    My advice in using a tube head is try the 4 cable method Line 6 describes in their tutorial. If you are just going to go into the effect return bypassing the amp preamp then just get a power amp, convert to stereo L/R speakers and take advantage of the cool panning and split dual amp capability.
