Dec 5, 2011 12:03 PM
Pedal does not go lower than 30% engaged
Like (0)
I bought my POD HD in the summer and when I started using the the Wah effect, I noticed that my pedal does not engage lower than 30%. This is extremely annoying because now If I want to Use the Wah effect for a certain part in a song, it will be incorporated into my tone.
-does anyone else have this problem?
-Will the warranty cover this problem? If so how do I go about contacting line 6 about this?
-are there repair shops that can fix this issue?
If you can answer any of these questions it will be greatly appreciated.
Not sure which model you have, but it sounds like you need to calibrate the pedal.
Here's the instructions for the HD500: http://line6.com/support/docs/DOC-2223
and here they are for the HD300/400: http://line6.com/support/docs/DOC-2044
Also, you might check the controls in HD Edit. I belive you can set the wah's position min & max there.
