1948 Views 34 Replies Latest reply: Oct 29, 2012 8:23 AM by Jessycd RSS
hamza4best Just Startin' 58 posts since
May 21, 2011
Dec 6, 2011 6:54 AM
Pod hd500 for vocals
Hey i'm thinking of buying the pod hd500 and i saw that it has a mic plug in too so i can do vocals with it as well..Now i practice and jam with my friends so is it possible to connect it to my amp(spider 4 15w) and use it for guitar and vocals at the same time? i mean can i assign effects for guitar and vocals separately at the same time? and will i be able to do distorted vocals with it? and lastly all the effects which are there in the pod for guitar can they all be used for vocals too?
cheers
  • BigChas52 Expert Line 6 User 2,315 posts since
    Mar 12, 2007
    Dec 6, 2011 7:01 AM (in response to hamza4best)
    Re: Pod hd500 for vocals
    All of the effects are available for vocals.  You can also create twop separate channels.  Note that there are no vocal pre-amps though, so for your vocal "channel" you'll use effects only.  Also note that the HD500 has a hard limit of 8 effects for both channels combined.
        Mar 26, 2007
        Dec 8, 2011 2:27 AM (in response to hamza4best)
        There is no vocal pre-amp as such, by which I mean there is no amp or pre-amp model for vocals.   The XLR microphone input does have a basic pre-amplifier built in just to get a decent level with a microphone, but that's it.  You can use all the FX and any of the guitar amp models with a microphone if you wish.
        Can you get a distorted vocal sound?  Yes, by using the distortoion FX.  Will it sound like Matt Bellamy's distorted vocal sound?  Maybe and maybe not.  You will have to experiment.
        Nick
            Mar 26, 2007
            Dec 8, 2011 3:08 AM (in response to hamza4best)
            You will have to try it, but personally i would say it could be OK for rehearsal depending on the amp you use, but for gigs????  Hmmmm.... I wouldn't really think it suitable, but as I say you will have to try it.
            How to set it up?  Create a patch with two clear signal paths and with the inputs assigned as follows:  Input Source 1: Guitar and Input Source 2: Mic.
            The easiest way to show you is to send you an example patch (attached).  Load it into HD500 Edit and take a look.  It's just an example. Don't take too much notice of the actual amp model and FX I've used, but pay attention to the Input assignments and how I've split the signal chains with the Mixer block right at the end.  I've panned the outputs hard left and right, which will be mixed to mono if you use one 1/42 output only to feed your amp.   Notice I've boosted the Right channel in the Mixer by 10dB to raise the level of the mic.  I have no idea whether this is too much or too little as I have just done this as an exercise in POD HD500 Edit alone.  You may find that adding some EQ in the mic channel will help as well as perhaps adding some compression.  That's all going to be up to you
            Nick
                Mar 26, 2007
                Dec 8, 2011 4:49 AM (in response to hamza4best)
                It will not be loud enough for a gig with a live drummer, bass player and other instrumentalists I'm certain.
                You will need to connect the outputs from your POD to the CD/MP3 input of the Spider IV15.  In all honesty it should sound OK for guitar at home using the POD as the front end, but for vocals I really don't think it will be good for more than getting a guide.  The Spider IV 15w is more of a practice amp to be used in a domestic environment IMO.   I think if you want to use your POD HD500 properly then a more powerful system, whether that be just a PA system through which you can put the POD and vocals separately, or whether it be a bigger guitar amplifier plus PA would be worth looking into.
                Nick
                    Mar 26, 2007
                    Dec 8, 2011 7:09 AM (in response to hamza4best)
                    It should be OK for home practice and playing along with backing tracks.
                    As for a PA - they come in all shapes, sizes and prices.
                    You can set your amp to a clean state.  I don't know whether the Tap button trick works on the Spider IV15.  You'll have to try it
                        Mar 26, 2007
                        Dec 8, 2011 8:56 AM (in response to hamza4best)
                        1/4" out from the POD to the front input of the amp
                            Mar 26, 2007
                            Dec 8, 2011 9:25 AM (in response to hamza4best)
                            You'll really have to experiment with the POD and find out the best settings for the mic which suit you.
                            The most cost effective?  That's a big question and one that could have a whole load of different answers.   If you have a POD HD500 and you need volume as well as clarity and proper vocal capability a small PA would probably be the most cost effective in my opinion, but as I say there are lot of possible answers to this/
                            Nick
                                Mar 26, 2007
                                Dec 8, 2011 10:05 AM (in response to hamza4best)
                                hamza4best wrote:
                                so which one you'll recommend then?
                                You'll have to look into what's available where you live I'm afraid.  I'd be looking at a couple of powered 12" speakers and a small mixer minimum - maybe one of the Behringer Xenyx mixers.  I use one of these with a pair of dB Opera 405 powered speakers for rehearsal.  That's not necessarily a recommendation, but it is a solution that works reasonably well for a vocal PA.
                                A mic pre-amp's main purpose would be to provide a flat frequency response level boost to match volume with other instruments and microphones fed into the PA.  Like a guitar amp pre-amp, a mic pre-amp may have tone controls to shape the sound of the vocals.
                                Line 6 rarely talk about future plans for their products, but anything is possible I guess.
                                In my opinion you will definitely need a PA of some description foir vocals at some point in your musical adventures.  whether you have to buy it or whether it's a joint purchase between band members is another thing.  You can also use the PA with your POD HD500.   A guitar amp is never a good idea for vocals IMO.   Longer term, i would suggest that you may want to purchase a decent valve guitar amplifier and use your POD with that.
                                Nick
                              • borehead Just Startin' 9 posts since
                                Oct 14, 2011
                                Dec 8, 2011 6:44 PM (in response to hamza4best)
                                A preamp is not a firmware thing, it's hardware. In either way, you will need a PA. As said before, vocals through guitar amps is in the most situations not a good idea. A preamp for vocals beef up the signal, makes it warmer, and not so "sterile" sounding.
    Mar 26, 2007
    Dec 6, 2011 7:03 AM (in response to hamza4best)
    +1 to BigChas
  • Mhomho Just Startin' 53 posts since
    Mar 20, 2009
    Dec 8, 2011 1:30 PM (in response to hamza4best)
    You can see here an example of the HD500 as a vocal FX unit.
    http://www.rtve.es/alacarta/videos/television/conciertos-radio-3-damien-lott/1022881/
    On the first song I use it to loop a phrase. Some pattern tremolo too on vocals and delays of course (analog delay w/mod)
    On the second song I use the rotary sim on the bridge...
    Lots of delays+reverbs all over the gig...
    Jan 27, 2010
    Dec 8, 2011 3:26 PM (in response to hamza4best)
    The newest version of HD500 flash memory comes with Vocal presets to get you started:
    New Presets – This firmware includes lots of new presets.  Many of the pre-existing Set Lists have gotten new presets and reordered based on customer feedback.  The “BASS/ACO/VOC” Set List includes presets which provide a starting point for bass, acoustic guitar, and vocal processing.
    Avalible here:
    http://line6.com/software/readeula.html?rid=4361
    Thanks,
    David
    Line 6 Customer Support
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
