851 Views 9 Replies Latest reply: Dec 17, 2011 11:16 AM by nathanbcook RSS
panthur Just Startin' 10 posts since
Nov 14, 2007
Dec 7, 2011 11:57 AM
Pod HD 500 Dropping PC Sound
Hello.
I have had my Pod HD 500 for about a week.
I'm using it connected via USB direct to my motherboard (i.e. USB sockets at the back of the PC, not on a riser card etc). Every now and again the sound from the PC will drop out and stay that way. The guitar sound continues to work fine.
I'm using headphones connected directly into the back of the Pod HD 500. The Volume mixer application within Windows 7 is showing sound output (The small green VU style meter is working), but no sound comes through the headphones. This seems to be random as it will work fine for a long period of time, and then just cut out.
It appears that the drivers are causing some software issue within Windows 7 (Fully updated) as once this has happened, the Sound control panel application locks up if I try to subsequently disable the Pod HD 500. The volume mixer also locks up after a short while. Forcing a reboot which then seems to solve the problem. This is on a Windows 7 64-bit installation fully updated and with no other problems prior to this. There is also a Creative Labs X-fi XtremeMusic in the system, the POD HD 500 is set as the default sound card, x-fi drivers are fully up to date. I used to use a Digitech GNX 4 alongside the X-fi in a similar configuration without issue.
Does anyone have any recommendations to a solution (Perhaps there is a BIOS setting issue, it's an ASUS P5K motherboard on fairly standard settings, i.e no overclocking) , or is this a driver issue for which a fix is in the works ?
Cheers.
    Mar 26, 2007
    Dec 8, 2011 1:16 AM (in response to panthur)
    Re: Pod HD 500 Dropping PC Sound
    Hi
    Asus motherboards and the P5K series were pretty reliable as I know from personal experience.  However, I assume this is a home built PC?   I have built many PCs in my time and part of the 'fun' can sometimes be resolving the odd curved ball that sometimes gets thrown.
    There are no issues with the POD HD500 drivers with Windows 7 64 bit AFAIK, so I'd be nore inclined to look more closely at your computer.
    Is your BIOS up to date?  Are all the chipset, graphics and other device drivers up to date with the WHQL tested versions (non WHQL - particularly graphics drivers can sometimes be a source of trouble)?
    What about the computer's memory modules?  Are they listed on Asus' QVL for your motherboard?  Memory is another pet topic for me when machines lock up for no good reason.
    What else is attached to the USB buss and might have higher priority than the HD500 and cause a conflict?
    Do you have a wireless network adapter attached to this computer?  If so turn it off or temporarily disconnect it to see if that improves matters for you.
    Have you thought about fitting an inexpensive third party USB 2.0 interface card to your PC?  This may resolve the issue.
    Nick
  • lef38 Just Startin' 34 posts since
    Sep 4, 2011
    Dec 8, 2011 8:05 AM (in response to panthur)
    The same happens to me, not very often, it *seems* to be related when I switch the pod HD500 on/off several times during the same Windows session.
    For example, when this happens, Windows Media player would load  a mp3 but refuse to play it: its Play button is disabled.
    I have to reboot if I want the Windows sound back.
      Sep 4, 2011
      Dec 8, 2011 12:22 PM (in response to lef38)
      It just happened again;  i was selecting a preset with the footswitch, and the pod crashed. At the same time an avi that was running in Windows media player, was stopped, and no sound was available in Windows anymore.
      HD500 edit was running during all that time.
      I have Windows 7.
    • Kneehow UberGuru 6,750 posts since
      Dec 26, 2007
      Dec 12, 2011 9:54 AM (in response to panthur)
      Panthur... let's focus on your HD500 by itself.
      Does this high pitched tone occur ever when the HD500 is powered up but without any connectivity to your computer? This is important to establish.
      Second of all, have you tried installing the latest USB driver on a different host PC (or Mac) and test the behevior of USB connectivity with your HD500 to a completely different host? If the same exact symptoms are occurring there is most likely an internal issue with your HD500, yes.
      If you get a chance to re-flash the HD500 (with your current host PC), please do so. I'd opt to not keep existing patches/presets when prompted in the Monkey wizard.
      After a re-flash, disconnect and power off the HD500. Before powering back on, press and hold the Left Arrow (on the 4-way directional keypad to the right of the HD500's LCD screen) and power on the unit while continuing to press and hold that switch until the Preset appears.
      Re-test. To me, if you can test the USB behavior on a different system at least we can A/B the behavior of the HD500 with two different hosts. Hopefully the unit itself isn't with issue, but if so we can easily help you out as it would be a warranty fix.
      • nathanbcook Just Startin' 1 posts since
        Sep 13, 2010
        Dec 17, 2011 11:16 AM (in response to Kneehow)
        I have this same issue.  I'll be using HD500edit working on a tone then all of a sudden the view will switch to two blank fx blocks then the amp/mixer.  The extra blocks you typically see are gone.  High pitch sound (almost deafening).  I have yet to have this occur when editing patches directly from the HD500.  When I unplug the power from the pod, I immediately get a BSOD on my PC.  This has happened to me at least 5 times now.  It happens more often than not when using HD500edit.
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Dec 15, 2011 5:13 PM (in response to panthur)
    RE: Pod HD 500 Dropping PC Sound
    Hey panthur,
      It has been at least 72 hours since we've heard from you. We're going to assume your question has been answered. If it has been answered, please award points to whoever was helpful and/or answered the question.
      In the event your issue has not been resolved, I created a support ticket for you so we can continue to communicate. Please respond to the ticket. Thanks!!
      Q: What is a support ticket?
      A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link to the ticket when a Line 6 Support Representative responds to it. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support. Also, in your account, click My Account, then click Support Tickets to view the support ticket. Here’s a shortcut:
      http://line6.com/account/tickets/view/
      Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host, and also that your email account is receiving messages at all.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
