501 Views 5 Replies Latest reply: Jan 22, 2012 4:55 AM by magischmeik RSS
magischmeik Just Startin' 5 posts since
Aug 25, 2009
Dec 10, 2011 8:19 AM
Win7 / Studio UX1: Amp Models not working in POD Farm 2.51 and Reason 6...
Hi there,
I have a studio ux1 with several model packs installed.
factory add-ons: fx junkie / POD Farm 1)
purchased:  bass ext. / power pack / metal shop / collector classics / POD Farm 2 / Propellerhead Record Add-On
I was using it with no problems at all on my old vista computer together with propellerheads record.
the podfarm also worked perfectly.
Right now i want to setup reason6 & studio ux1 on my new windows 7 computer.
Specs in short are:
Intel Core i7 860 @ 4x 2.8GHz / 8GB RAM
System HD: OCZ Vertex SSD
OS: Win7 Pro 64Bit SP1
Novation Remote49 SL MkII (Automap 3.7.4)
Studio UX1 (drivers 4.2.4.9 / firmware 1.01)
Line6 Monkey 1.43
License Manager 1.01
POD Farm 2.51
Propellerheads Reason 6.0.1 (UX1 ASIO)
So far the amp models do not work at all in POD Farm 2.51 standalone and Propellerheads Reason 6.01.
the sound does not change.
Reason 6 freezes for at least half a minute when i try to add a line 6 amp to the rack.
afterwards it displays the amp in the rack but the sound stays the same.
I can't even access the free amp models that came with propellerheads reason.
I also have problems loading songs created with propellerheads record that have amps in the rack.
POD Farm 2.51 standalone does not freeze when changing gear and always says i have all the needed models installed for the preset,
but also does not change the sound.
Both, the computer and the device are authorized with the License manager 1.01.
Everything shows up correctly in the License Manager.
Please help me.
thanks in advance...
  • BigChas52 Expert Line 6 User 2,315 posts since
    Mar 12, 2007
    Sounds like your software install may have gone wrong.  Here is a troubleshooting doc that may help.
    http://line6.com/support/docs/DOC-2304
      • Line6Hugo Line 6 6,580 posts since
        Apr 8, 2007
        I can see that you have your computer and the Line 6 harware authorized.  If you are primarily using the Line 6 hardware interface, please de-authorize your computer and re-authorize just the UX1.
        Also, please remove all other USB devices (except for a mouse and keyboard on a desktop computer) while troubleshooting this problem.  Completely remove ANY USB hubs, even if not in use, and test the hardware on all of your computer's USB ports, preferably the back ports on a desktop system.
        You may also want to try all of the tips in the following USB Troubleshooting document:
        http://line6.com/support/docs/DOC-4282
        Regards,
        Line6Hugo
  • rushmpeg Just Startin' 5 posts since
    Oct 23, 2008
    I'm struggling with similar problems but in my case it works randomly (about half of the time) when I open the soft or change presets -> dry sound. The volume knob of the amp/pre is the only thing that works then. When it happened with the 1073 sim loaded I noticed that turning the gain knob at max gives a non-musical digital distortion, the eq and high-pass knobs are not changing the sound.
    I'm using win7x64, I already tryed the uninstall/reinstall + removing all folders manually like said in the doc.
    I'm following this thread closely in case it may help me aswell
    D.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
