1 2 3 ... 12 Previous Next 9732 Views 177 Replies Latest reply: May 25, 2012 7:47 AM by stratchamp RSS
BulldogXTRM Just Startin' 83 posts since
Jul 31, 2011
Dec 10, 2011 9:27 AM
My HD500 is SQUEELING and my eardrums are going to BLEED! I need help!
I've been editing my patches with my HD500 edit and occasionally my HD500 will go out of sync with the HD500 edit software and start an ear piercing squeel. This is really bad because I use a set of cans (Shure SRH440) at a reasonable level for my main editing and then I tweak the patch live. Obviously this is going to cause me some problems if it keeps happening because my eardrums are going to bleed!!!
Pulling the power to the HD500 is the only way to stop the squeel. Once it reboots, it comes back up and everything is okay except  I've looked at several of the other posts and commented on one of them, but everyone seems to think that this is a because of a bad patch.
I don't.
The main reason I don't think this is a bad patch is that after the reboot the patch is up and running with no problems. I've tried rebuilding from scratch and it happens then also.
This isn't a problem with every patch build just an occasional problem. I think that for some reason the HD500 edit software and the HD500 going out of sync has something to do with it. I've noticed that sometimes even when not editing a patch that the software will go out of sync with the Pod.
Can Line 6 look at this and try to roll out a quick update to either the HD500 edit software or the Pod firmware to fix this?
Bookmarked By (7)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
