Dec 10, 2011 6:36 PM
JTV-69 and Line 6 VDI cable: problems with 12 string tracking
Like (0)
Hello. I have a korean jtv-69 and recently bought a line6 VDI cable direct from line6. This is the cable that is like a regular guitar cable but has the more solid ethernet connections at each end and will power the jtv without the battery. anyway, i've noticed that the variax acoustic 12 string tracking is very poor when using this cable as well as the VDI cable included with the purchased guitar (new from line6 as well). there are all sorts of warbling and artifacts especially on the low E string and worse with chords than single notes. the tracking problems are not present on any other 6 string acoustic or electric variax models.
i've tried building presents in my pod hd 500 from scratch as well as using line6 pre-built presets and have the same problems. i've tried it using the pod hd edit on and off, powering the pod hd 500 on and off, switching presents back to a 6 string electric and then back to the acoustic 12 string. no dice. it's always there with the VDI cables but the tracking is generally very good with a regular guitar cable.
am i missing something here? is this a known bug or is there a fix that i'm overlooking? i searched the forum here with no luck. i have the latest firmware on all equipment. i would really like to be able to use the VDI cable in a live setting so i'd never have to worry about the battery power but there is no way i could use a 12 string setting like this.
any ideas or suggestions to fix this issue?
thanks
Personally I think they over-cooked the defaults a bit with reference to the 12 string models. I think they did with the older Variaxes too.
WorkBench is your friend however. ![]()
Make sure your guitar does not buzz when you fre the strings. Make sure the intonation is correctly adjusted and perfectly in tune before you do anything in WorkBench.
Now in WorkBench you can adjust the detune value (in cents) and the mix volume of the 'virtual' string in each 'pair'. I usually drop the mix volume and bring the virtual strings near enough in tune with the real strings and this cleans things up a lot.
The pitch shifter circuitry 'hears' the pitch of the real string and then has to make a best choice for the pitch of the virtual string based on what it hears. It is vital therefore that the string can be heard cleanly by the circuitry, so you need to play cleanly and without misfretting or buzzing strings.
Nick
hi nick,
thanks for replying. the problem really seems to be that the tracking issues are only present when using the VDI cables i got from LIne6. when i use a regular 1/4" guitar cable to plug into the pod hd500, it tracks the 12 string models fine. I agree that the 12 string models are cooked a little too much by line6 but what i am talking about is a different issue all together. the VDI cable does not seem to transmit data fast enough for the connection to keep up and make the tracking error free to within a reasonable amount. either this is a failing of the cable or the conectors or the processors, etc. I state this simply because all other things being equal and unchanged, the 1/4" connection doesnt suffer the tracking issues.
any other ideas about this that anyone might have?
thanks!
andy
Interesting...
This might be related to the issue I described here : http://line6.com/support/thread/71849?tstart=60
If I'm right, the problem could be coming from the power being provided by the POD (through the VDI cable).
Maybe the POD power line is too noisy (typically battery power is noise free), disturbing analog circuitry (both mag pickups and piezo used for models), and causing tracking issues on the 12 string models.
Fredo.
hi. thanks for the reply. i'll check out your post.
Line6: any suggestions? Is this a new issue for you or a known bug? Any suggestions to remedy?
Thanks
I haven't heard this before and I will test, but can you provide us a sound recording example of you both playing a 12 string with the VDI and doing the same with a 1/4" cable so that we can hear this problem that you are experiencing?
Regards,
Line6Hugo
Hi. thanks for the reply. i will see if i can record and upload it this weekend. what's the best method to post an mp3 or wav file on here?
thanks
You can upload an MP3 file directly by simply attaching the file, however, depending on the browser you use you may need to post a reply and then go back and edit it to expose the Attach File button (not sure why it works this way either TBH, but it should do the trick
Nick
hi nick. thanks for the tip. i'll see if i can do it now as i have the file recorded.
the first couple minutes of noodling is with the VDI cable attached and no other inputs in use. I mic'ed up my PA cab with an sm57 into a firepod to reaper. no FX, compression, etc in use at all. just the straight signal coming from the PA. the second part of the noodling is the VDI cable out and a standard 1/4" guitar cable in use. no other changes made to the setup at all.
thanks
I've just taken a listen - and to be fair, only a quick listen without the benefit of headphones and I can hear some differences with the lower string pairings I think.
Just a thought. But have you got the input sources in your POD set correctly when you are using the VDI cable. The JTV sends digital audio on two channels: Variax Ch1 (modelled sounds) and Variax Ch 2 (magnetic pickups). Your POD HD500 has three Vaiax related input sources: Variax (for older Variax guitars, but with a JTV, it will mix Variax Ch1 and Variax Ch2 and possibly lead to some odd sounds); Variax Ch1, and; Variax Ch2. If you have somehow selected both Variax Ch1 and Variax Ch2 you will also get the two channels mixed and it will possibly sound odd.
It sounds as if on the lower strings you might have a little bit of fret buzz which will affect how the tracking responds, but I can't be certain from what I've heard and the way I've heard it
I don't know if you have had much of a tweak at all in WorkBench with the detune settings. If anything it sounds to me as if the lower strings are maybe a little bit too detuned and a bit loud on the virtual string level - but as I say I haven't listened under ideal conditions yet ![]()
Nick
hi nick. thanks for the reply.
i will check out your suggestions and see if that helps.
will post back soon with update one way or the other.
ok. i tried your suggestion, nick, to change the inputs around. this seems to have solved a lot of the out of tune sound i was getting. there remains one issue though that i have not been able to eradicate with input settings or changing the 12 string parameters in the workbench. if you listen to my mp3 posted above, right around the 1:23 mark, on the open G string, there is a "toy organ" like continuous tone whenever the open G note is struck. nothing i do in workbench (eg: changing the string detune or volume of the detuned string, or changing the inputs on the pod) seem to eliminate the sound. any ideas? is this a piezo problem? it's pretty noticeable now that the majority of the tracking issue has been taken care of.
thanks for your suggestions before.
anyone else able to weigh in on the "toy organ" sound i mentioned in this last post? thoughts?
thanks
+1 to Nick, I think I hear a mix of the dry guitar and the DSP based signal. What are you Variax input settings set to on the POD HD 500? Listed on page 3/9 of the setup menu on the 500.
Thanks,
David
Line 6 Customer Support
hi david: at the time of the recording, the inputs were Variax CH1 and input 2 = guitar
currently, i run input 1 = guitar + variax ch1 and input 2 = mic and that seemed to relieve a lot of the problem. if you listen to my mp3 noodling above at the 1:23 mark, you can hear a real synth-y, toy keyboard sort of tone on the open G string. i have yet to be able to get this to go away no matter what settings i use in the pod or the workbench software. it really stands out in the 12 strings but no where else. i recently changed strings as well on the jtv69 and it is still there.
ideas?
thanks
Do you get that synthy soud you describe if you just hit the G string by itself? Do any other stirings do this? If you get this warble noise on just the G string on more than one fret, there may be a hardware issue with the guitar which would require it to be serviced. So if the re-installation of the flash memory has not cleared up that problem, we would need to get it back here to get it serviced.
Regards,
Line6Hugo
Hi Hugo,
I just updated to the latest flash in the tyler. i've been playing for a few minutes and I think that the Tyler has, indeed, been improved in it's tracking with the VDI cable and the newest firmware update. Thanks for that!
The synthy tone is still present to some degree and it is evident on the E-A-D-G strings with the most audible on the D-G strings, open strings and fretted notes all have the overtones. The overtone (synth-y) is more noticeable on the factory settings than the ones I have gone in and decreased the volume of the de-tuned sounds in Workbench. I am wondering if this is a software artifact vs. a hardware defect??
is there any authorized service dealer in my area (zip 23518 in Va.) that could check it out? I'd hate to part with my Tyler for a long time (shipping back to Line6 in Cali) unless I/We were really certain it was a hardware issue. Yes, I love the guitar that much! It is really a wonderful piece of gear
and I hate to put it down!
The synthy overtones are present when using any 12 string model in the variax, with either the line6 VDI cable or any 1/4" guitar cable I've tried. It does not seem to be present is any other model.
Thanks for your help with this!
I have a JTV-69 connecting through a POD HD 500. I too am having issues with alt tunings when connected with a VDI cable. I have tried a varietry of combinations on the input sources..what is the correct input source setting for my rig? I have no issue when connecting with a regular guitar cable
Thanks
correct settings that worked for me are input 1: guitar + Variax ch.1 and input 2: mic
hope this helps.
just wanted to see if the Line6 folks had any further thoughts on my post in this thread from 1/8/12. please let me know. thanks! ![]()
Hobbes,
I have opened a support ticket for you to resolve this issue. Please use the following link to view your support ticket:
http://line6.com/account/tickets/
Regards,
Line6Hugo
Hi. after having the guitar back for awhile and playing it, the problem is better but not entirely sorted out. I guess the adjustments made by line6 were the best that can be done. the 12 string problem isn't as prevalent especially in a band setting but is still noticeable in a solo setting. not sure that i'd want to gig these 12 string patches and that's a shame as it was one of the big draws for me to this JTV.
