517 Views 7 Replies Latest reply: Apr 5, 2012 5:02 AM by hatecrewabeer RSS
hatecrewabeer Just Startin' 9 posts since
Jul 10, 2011
Dec 11, 2011 11:28 AM
Recording using the HD 500 ?
I`m trying to record using my HD 500 for the last few days ( USB as the only audio interface) but its not giving me the desired results!! I tried using the HD`s amp modelers and other cabinet modelers , i tried recording a raw bypassed signal and then using guitar rig 3 to tweak the sound , and also tried recording the HDs tone directly. I use sonar 8 , any suggestions how i can get a good output using the HD as the audio interface?
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Dec 11, 2011 12:17 PM (in response to hatecrewabeer)
    Re: Recording using the HD 500 ?
    Check the Sonar audio setup to make sure you are using the HD500 and its ASIO driver as the audio input/output device.
    If you are still having the difficulty, please describe / compare what you hear between the sound you hear from the HD500 headphones while recording, and the recorded sound. Use the wet (not dry/ raw) signal for this comparison.
    Make sure you are monitoring playback of the recorded sound using the HD500 outputs (headphones / XLR / 1/4").
    • Seppi Just Startin' 74 posts since
      Aug 14, 2009
      Dec 12, 2011 7:20 AM (in response to silverhead)
      I'm also using my HD500 as my main interface. I just bought a pair of powered studio monitors. When I connected my studio monitors to my HD500 from the XLR-out of the HD500 to the XLR-in of the powered monitors, the volume was very VERY weak. I tried to connect the monitors to the HD500 using a trs-to-rca cable from the headphone-out of the HD500 to the rca-in of the monitors. The result was good. The volume became loud! I think its 10 times louder than the 1st setup when I was using the XLR-out. How come its weak when I use the XLR-outs?
  • Apologist Iknowathingortwo 638 posts since
    Jan 24, 2007
    Dec 11, 2011 12:27 PM (in response to hatecrewabeer)
    I use same set up only I use bean and use USB:
    If you do not use ASIO drivers youw ill get issues like muffling of sound and lagging playback
    With Asio I have no issues other than occasional clipping if I dont make a patch right but that's my fault not the HD Bean
    Aug 14, 2009
    Dec 13, 2011 6:50 AM (in response to hatecrewabeer)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
