60 Views 1 Reply Latest reply: Dec 12, 2011 1:50 PM by amx05462 RSS
jeffwellman Just Startin' 1 posts since
Dec 12, 2011
Dec 12, 2011 12:53 PM
Acoustic 700 hum
I have had my Acoustic 700 repaired for a loud hum when using the 1/4" cord twice and they never got it fixed for long..  I'm at a point now where I'd rather just used the digital cord and forget trying to get it repaired. I use it through my POD XT Live all the time.   Is there any kind of box I can use or small amp that will accept the digital cord and power the guitar so I don't have to haul the POD around or am I just outta luck?
  • amx05462 Power User 3,495 posts since
    Sep 1, 2008
    Dec 12, 2011 1:50 PM (in response to jeffwellman)
    Re: Acoustic 700 hum
    most likely  its a bad  ground  to the  output  plug   you can probably  fix  it yourself   worse case  the   plug  has  gone  bad.. and you need  a replacement  but id  check all connections  and  solder  joints..  as to the  amp...  well  the  only  ones  i know that  take  the  vdi    are  line  6 amps..
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
