528 Views 11 Replies Latest reply: Jan 3, 2012 2:25 PM by Line6Tony RSS
gnfreire Just Startin' 54 posts since
Mar 28, 2007
Dec 13, 2011 2:00 AM
L6 link Vs Guitar input
I'm comparing the signal and sound with guitar straight to DT50/25 amps Vs guitar into Pod Hd300/500 then L6 link to DTs using the same amp, the same cab, the same topology, etc and the result is A GREAT LOSS IN SIGNAL OUTPUT AND TONE SUCKING when its in the POD path. When its direct into DTs guitar input, the sound and dinamic response from the amp is PERFECT!!!!!
I really want to use the Pods fx and relay switching to DT amps but the sound directly into guitar input is much better!
Anybody there getting the same problem??
Is there a way to avoid the tone sucking in the POD/l6 link path?
  • MGblade Just Startin' 110 posts since
    Dec 5, 2007
    Dec 13, 2011 8:56 AM (in response to gnfreire)
    Re: L6 link Vs Guitar input
    i,ve tested the difference of my dt25 topology's and the ones in my hd500 trough l6 link, the only difference i,m getting is that some how the dt25 pre amp has more channel volume, soundwice it's the same (in my ears).
    but i guess it is supposed to sound the same since the models in the dt25 are hd models.
    hope you can figure it out
      • gregr Iknowathingortwo 639 posts since
        Oct 26, 2009
        Dec 13, 2011 9:50 AM (in response to gnfreire)
        If you're using the same cable to connect your guitar to either the HD or the DT then there will be no relative signal loss.  The L6 Link is a digital connection.
            Oct 26, 2009
            Dec 13, 2011 2:06 PM (in response to gnfreire)
            I'm not trying to imply that your concerns aren't valid, just that you cannot hold the L6 link or the cable providing it responsible. 1s and 0s don't magically morph themselves into something that anyone could readily describe as "tone sucking".
            Perhaps this has something to do with the preset you're using including what models you're using, if you're using cabinet simulation (which you cannot disable on the HD300) as well as the various levels of the models and mixer block.  I would think you would get very consistent results between the HD500 and modeling preamp in the DT using any of the four respective preamp-only models without cabinet emulation.
  • Line6Tony Line 6 Support 1,917 posts since
    Jan 16, 2007
    Dec 20, 2011 9:08 AM (in response to gnfreire)
    Can you give us the details of the setup and the tone settings so we can reproduce it here? You should start with the most basic tone that displays this problem. Also, please try different XLR cables to connect L6Link to see if that makes a difference, just so we can rule that out.
      Jan 16, 2007
      Dec 22, 2011 1:02 PM (in response to Line6Tony)
      Please let us know if you still need help or we will close the thread. Thanks.
      • Line6Hugo Line 6 6,580 posts since
        Apr 8, 2007
        Dec 29, 2011 9:17 AM (in response to gnfreire)
        gnfreire,
        Thanks for the setup info, but I need you to be more specific to know EXACTLY which amp models you are selecting.  So please provide the amp model names you are selecting on the POD HD300 for this comparison as the appear in the screen when you select them.
        Thhis will help us know exactly what you are doing to compare.
        Regards,
        Line6Hugo
    Jan 16, 2007
    Jan 3, 2012 2:25 PM (in response to gnfreire)
    RE: L6 link Vs Guitar input
    Hello. We haven’t heard back from you, so we're going to assume your question has been answered. If it has been answered, please award points to whoever was helpful and/or answered the question.
      In the event your issue has not been resolved, I created a support ticket for you so we can continue to communicate. Please respond to the ticket. With us talking via the ticket, I will mark this thread answered.
      Q: What is a support ticket?
      A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link to the ticket when a Line 6 Support Representative responds to it. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support. Also, in your account, click My Account, then click Support Tickets to view the support ticket. Here’s a shortcut: http://line6.com/account/tickets/view/.
      Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host, and also that your email account is receiving messages at all.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
