Dec 19, 2011 7:18 PM
Line 6 monkey wont detect my fbv express mk2
Like (0)
I'm trying to download a few tones for my spider IV amp 75w. I have my pedal hooked up to the computer, and i have the line 6 monkey program installed. what am I missing? Do i need to authorize my pedal?
Yes, you do need to register your pedal with Line 6, along with the amp.
There have been many threads on these forums about Monkey not recognizing the controller. Standard solutions include trying a different USB port. What OS are you using? Windows (version) or Mac?
I had problems doing the v2.0 update with Vista, but was able to do it on another computer running XP. Spider Edit (that's what you use for loading tones from customtone.com) works fine for me with Vista.
The first thing you will need to do is download and install the latest version of Line 6 Monkey for your operating system that you can use to download the latest Line 6 software:
Windows Line 6 Monkey 1.43:
http://line6.com/getrelease?rid=4223
MAC Line 6 Monkey 1.43:
http://line6.com/getrelease?rid=4222
The next thing you need to do is to update your amps firmware in order for you to be able to connect it to your computer and use it with Spider IV Edit, we have a video tutorial for this process at the link below:
http://line6.com/support/docs/DOC-2081
After updating the firmware, you will be able to use your amp with the Spider IV Edit software. You can edit, save, and load presets using Spider IV Edit.
I have marked the answer that is correct for your question, please help out the community by marking other suggestions that were helpful to you as "Helpful Answer".
If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
http://line6.com/support/community/support/
For more information about using the Online Technical Support System please review our FAQ at the link below:
http://line6.com/support/docs/DOC-1451
Thanks!
Thanks
im still new to the site, anyway to delete this discussion?
