Dec 20, 2011 4:40 PM
Pod x3 live ASIO 24 bit 96000
Like (0)
I'm using my pod x3 live as an interface for recording. I thought that It did 24 bit at 96000 but the driver will only let me get as high as 48000 in the ASIO control panel. Is there a reason it doesn't go up to 96000?
I just tested The POD X3 Live with our current Windows ASIO driver v4.2.5.1 within Reason 6.0.2 and Reaper 3.76 and within both applications I was able to use 96000 Hz sampling rate. Our driver only lists 44100 and 48000, which indicates to me that, if you plan on using 96000 within a DAW, it most likely will be up sampling 48000 to 96000 via sample rate conversion.
