Dec 21, 2011 1:14 PM
Help needed using the UX2 with Logic Pro 9
Like (0)
All I have is the UX2 and Gearbox. I'm trying to record the a mic input and a jack input at the same time but on different tracks on Logic Pro 9. I've set the input on logic as the UX2 and the output as default. The guitar signal is registering on Gearbox and the UX2 but not o logic at all.
I've spent hours sending e-mails and browsing forums and I can't figure out how to use the UX2 as a simple recording interface to record two guitar tracks (from the same guitar) simulatneously.
Please help!!
First, if you are still using Gearbox, please make sure to set the Source on the left hand side of Gearbox to Instrument+Mic. Once you do this, you should receive a message telling you that the Instrument signal will be sent via Record Sends 1-2, and the mic signal will be sent via Record Sends 3-4.
In Logic's audio tracks, you would need to set the input channels to 1-2 on one track to receive the Guitar input, and 3-4 on the other audio track to receive the mic input signal.
For further clarification, please go over the Gearbox Recording set-up guide on pages 2.7 and 2.34-35:
Regards,
Line6Hugo
Line6Hugo's answer above is correct. I have marked the answer that is correct for your question.
If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
http://line6.com/support/community/support/
For more information about using the Online Technical Support System please review our FAQ at the link below:
http://line6.com/support/docs/DOC-1451
Thanks!
