Dec 21, 2011 11:39 PM
HD500 Expression Pedal Toe Switch
Like (0)
Hello all,
I know this sounds like a ridiculously nooby question but should I be concerned that i don't see any 'intergrated toe switch' on the expression pedal? I guess this is the only way to be able to switch from EXP1 to EXP2. I have had the HD500 for 5 days, so this might explain my strange question.
The Toe Switch itself is inside the unit. It may take some pressure to activate it particularly when new, so you should stand on the toe down position of your expression pedal quite hard. Trying to activate it by hand is quite hard to do.
I don't know if this helps you at all?
Nick
basically, it's like turning on a wah. gotta step on it =)
and step on it HARD!... or rather with some weight
