242 Views 2 Replies Latest reply: Dec 29, 2011 12:49 PM by Line6Tony RSS
gerby1990 Just Startin' 1 posts since
Nov 2, 2007
Dec 24, 2011 8:40 AM
Possible to connect Pocket POD to hifi-amplifier?
I have recently purchased a stereo hifi amplifier that powers two 60W speakers. I have my pc connected to this amplifier. My main question is is it possible to connect the Pocket POD directly to that amplifier?
I'm concerned that voltage and impedance don't match and therefore blow up the speakers or causing other harm to my equipment. If connecting the POD directly to the amplifier is not a good idea, I could still connect the POD to the pc and from the pc to the amplifier, but i fear that might compromise sound quality when i'm playing along with a backing track for instance.
So I'm wondering what the output voltage and impedance is of both the Amp out and the direct out/phones.
The input sensitivity and impedance on the amplifier is 150 mV/50 kohms..
Any thoughts on this issue?
  • pbassred Just Startin' 29 posts since
    Sep 19, 2006
    Dec 27, 2011 1:45 AM (in response to gerby1990)
    Re: Possible to connect Pocket POD to hifi-amplifier?
    No problem.  That's what pods are for.  People plug in their Ipod and phones in all the time. Get yourself a jack to phono splitter cable.  Your amp has quite a high input inpeadance so you aren't going to be able to pass enough current to damage it.  In fact It might be a bit low.  Try it.  The absolute worst that can happen is that you find out that you need a DI box to make it sound better.
    PA Guys blow up speakers because they over drive their amplifiers ( shoulda bought a bigger amp) otherwise, It is almost impossible for the correct size amp to blow up speakers.  What you are doing is amplifing the sound of distortion which is an entirely different thing.
  • Line6Tony Line 6 Support 1,917 posts since
    Jan 16, 2007
    Dec 29, 2011 12:49 PM (in response to gerby1990)
    It just depends on your amp's inputs. The Pocket POD's 1/8" direct output is line level, so if your amp has this type of input, it will work. Pbassred's reference to a DI box is true if using the 1/4" output.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
