219 Views 6 Replies Latest reply: Jan 10, 2012 11:29 AM by Line6Don RSS
jani_verita Just Startin' 3 posts since
Aug 5, 2010
Dec 26, 2011 12:26 AM
Usb Problem
I can't connect my podx3 live to my computer via usb. I tried 3 different computers, drivers installed cable is ok. I think that problem in usb on pod. How can i fix it.
Service center is not option, because there is no line 6 service center in Kazakhstan.
If you can tell me exact model of usb chip i can change it by myself.
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Dec 29, 2011 5:43 PM (in response to jani_verita)
    Re: Usb Problem
    I'm sorry to hear about your situation... where in Kazakhstan did you purchase your POD X3 from? Did you purchase it new and if so, when?
    In the past, I've directed another customer in your country to our contact in Kazakhstan:
    Samat Show Technics Ltd
    88, Karasai Batyr Street
    050012 Almaty
    Kazakhstan
    Tel : +7 727 2582368
      • birro Iknowathingortwo 172 posts since
        Jun 27, 2007
        Jan 3, 2012 1:05 PM (in response to jani_verita)
        Re: Usb Problem
        Hey Jani. I'm from Brazil and I do understand your worry about being away from the U.S.A. and away from a service repair center.
        Let's try a thing but PLEASE don't think of opening the unit sending it to a technician. I'm 90% sure that it's a Windows problem. The drivers are tricky to be installed I had lots of problems at my first Line6 XT Live, than I got it.
        Which Windows are you using? Have you tried a different USB cable?
        Please follow these instructions carefully:
        1) Uninstall ALL drivers from Line 6 from your computer. Do it with the USB cable unplugged
        2) Turn off your computer (to clean up RAM memory, very important if it's Windows XP)
        3) Download the Drivers:http://line6.com/software/readeula.html?rid=4143
        4) Install the drivers (please, keep the USB unplugged!!! Don't plug it!)
        5) Almost at the end of the installation, the software will ask you to plug it. IMPORTANT: at the END of the installation
        6) Read carefully: Turn OFF (power off) your POD. Plug the cable on a different USB port on your computer (don't use the USB you're used to plug. Use another one for Microsoft Windows litterally install a new driver). Plug it with the POD Turned Off.
        Note: It's dumb but a usb driver installed for a USB port #1, won't work on USB #2 for example. So if you have removed the USB drivers, even if Windows hasn't deleted the driver for any reason, using a different USB port may help you.
        7) Computer USB plugged? POD USB plugged? Turn the POD On
        8) Wait to check if the unit will be recognized by your computer (Windows 7 will let you know in about 10-30 seconds with a message nearby your clock)
        Good luck and let us know the results! But please let's try everything before sending it to a technician and possibly losing your warranty or getting new problems.
        PS: if you don't make it work please reply and tell us. I still have another different tip for you but these 8 steps may be useful. If they don't work we're gonna try another ones
          • Line6Don Line 6 Support 5,274 posts since
            Mar 14, 2011
            Jan 10, 2012 11:29 AM (in response to jani_verita)
            Re: Usb Problem
            As Line6Perry mentioned above, we suggest that you have Samat Show Technics Ltd take a look at the unit for you. They should have access to the correct schematics and parts need to repair your POD X3 Live.
    Jan 27, 2010
    Jan 10, 2012 11:28 AM (in response to jani_verita)
    Re: Usb Problem
    If the X3 will not connect to multiple computers then it does need to go to an authorized service center for repair. I would suggest contacting the service center Perry suggested:
    050012 Almaty
    Kazakhstan
    Let us know how it goes.
    Thanks,
    David
    Line 6 Customer Support
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
