460 Views 4 Replies Latest reply: Jan 4, 2012 9:59 AM by Line6Don RSS
gareee Just Startin' 13 posts since
Sep 8, 2008
Dec 28, 2011 9:07 AM
DT25 preamp tube
Does the DT25 use the 12AX7 in the preamp stage? I'm having difficulty understanding how it is put together.  If it does, then I'm unsure how the the HD500 preamp models fit into the picture.  On the DT50 specs, it mentions that the 12AX7 is in the preamp stage, but it doesn't say this for the DT25.  Is it different? How? Is the preamp completely modeled, so that any distortion will be modeled?
Thanks again.
  • hollis1003 Iknowathingortwo 342 posts since
    Feb 6, 2007
    Dec 28, 2011 10:14 AM (in response to gareee)
    Re: DT25 preamp tube
        Feb 6, 2007
        Dec 29, 2011 5:33 AM (in response to gareee)
        Seems like you are understanding it correctly.  Marshall has a series of amps that do the same thing but all in the amp itself.  It's called the JMD series:
        http://marshallamps.com/product_range.asp?productRangeId=31
        They have finally discovered that they can better model the preamp section of an amp than the power amp section.
        Anyway, I have been using the POD HD 500 with a DT-50 head and a Line 6 4x12 with V30s for a few months now and I love it.  I used to have the HD147 (all digital with a solid state power amp) and it was OK but nothing like the DT-50.  The power amp section really makes a difference and the POD HD technology is very good, much better than the last generation.
        The only thing I can say is to try it out for yourself.  If there is no store in your area ask for members of this forum in your area that have one.  I would let people test out my set up if they were interested.
        • Line6Don Line 6 Support 5,275 posts since
          Mar 14, 2011
          Jan 4, 2012 9:59 AM (in response to hollis1003)
          +1 to hollis1003.
          The answers are on the threads that he provided to you above:
          "The two 12AX7/ECC83  tubes are not pre-amp tubes in the traditional sense.  They are both part of the power amp section.
          One boosts the overall level of the pre-amp output to drive the EL34's and the other is used as an inverter."
          Therefore the DT series amp include 4 different preamp models to choose from, when using in combination with one our HD series POD's, more preamp models from the POD can be used in place of the 4 internal preamp models of the DT.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
