358 Views 6 Replies Latest reply: Jan 3, 2012 4:06 PM by macphly RSS
macphly Just Startin' 4 posts since
May 23, 2009
Dec 30, 2011 12:00 AM
2 questions re: HD500 and DT25
Hi...a couple of questions:
1. I have been using my HD500 in my Soultone 1987PS's FX loop, effects only, no models. This is a great sounding 50 watt Marshall clone, but I'm trying to get away from mics. This has led me to find a great patch in the HD500 using the JCM800/Engl cab/Senn 421 mic. NOW, I thought I'd set up a patch with no modeling on the left and this amp/cab/mic on the right, hoping I could use the left channel with no amp model into my loop and then DI from the right balanced out of the HD500 to the board. However, it appears that inputs on the HD are not isolated so I always get a mix...IOW the model is my fx loop which doesn't sound good. Am I missing a setting somewhere, or is this something the HD500 wasn't designed to do?
2. I'm guessing that the HD500 won't do that, so I've been looking at the DT25. I notice that you've suggested PREAMP models, which makes sense. However, I'm really in love with this HD500 combination (JCM800 > Engl 412 cab > Senn 421 mic)...so with the DT25 can I get the cab an mic emulations to work with the JCM800 preamp model to get the same sound? If not, is there a way that I can send the preamp model to the DT25 and the amp model to the board?
I hope this all makes sense! Thanks for reading!
Jeff
  • gregr Iknowathingortwo 639 posts since
    Oct 26, 2009
    Dec 30, 2011 10:48 AM (in response to macphly)
    Re: 2 questions re: HD500 and DT25
    Please upload your preset.  I have a feeling you've placed a mono effect after the mixer block (this is assuming you have the mixer block set up correctly to pan your signals as you like).
    The HD500 can do what you want, but if it still doesn't work to your satisfaction buying a DT25 will not solve the problem.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
