185 Views 6 Replies Latest reply: Jan 25, 2012 5:46 PM by Line6Don RSS
btpentland Just Startin' 4 posts since
Nov 12, 2011
Jan 4, 2012 9:39 AM
After calibration, volume pedal is way too sensitive
I just purchased a Floor Pod Plus.  As a long-time POD 2.0 user, I upgraded mainly for the built-in volume pedal.  After following the instructions in the manual (which I see repeated here in the FAQs and on-line knowledge base), the volume pedal is FAR too sensitive.   It is fully off in the "heel" position, but then the slightest movement (maybe 1/8", a tiny fraction of full travel) and it goes to full gain.  So there is no difference in volume for 90% of range of motion.
Suggestions?
  • malenfant Just Startin' 8 posts since
    Dec 27, 2011
    I raised a similar issue http://line6.com/support/thread/77407?tstart=30
    I ended up "cheating" the calibration a little by not actually putting it all the way down in the heal position.  That moved the bite-point north a bit but it's still way too abrupt from my tastes.
    It's like what you might get on crybaby where the pot had the wrong taper...
    ...well sorry I can't solve it for you but maybe it's something to know this is a common feature to the model and not a specific fault on your unit or mine.
    I hope you get to grips with it.
      • Line6Hugo Line 6 6,580 posts since
        Apr 8, 2007
        You can try adjusting how you calibrate it using malenfant's suggestion.  Hope you can find a happy medium that works for you.
        Regards,
        Line6Hugo
            Dec 27, 2011
            >Certainly this can't be how it is designed to work.
            I suspect that's pretty much the situation.  But being generous designing a pedal to act as both a decent wah and volume control must be quite tricky.  Wah pedals typically have different types of taper than volume pedals.  There's a decent engineering challenge there in overcoming the fact that they are fundamentally different beasts...  I'm no sure how the crybaby with combined volume and wah does it or whether that works any better.  It seems to have patchy reviews.
            Maybe a higher end device would work optically and emulate the different response curves in software.  Ultimatley someone had to make a decision between building an uber-complex high end pedal versus building a more compromised one on a budget.
            It's a shame that none of the reviewers seem to have mentioned this though.
          • Line6Don Line 6 Support 5,275 posts since
            Mar 14, 2011
            Make sure to follow these calibration instructions:
            - Hold toe-switch on VOL/WAH and power unit.  The display will read ?PC? (Pedal calibration) and then ?000?.
            - With the pedal at toe-position, hit the ?A? button.  The display will show 100
            - With the pedal at the Heel-position, hit the ?B? button.  The display will show ?100?
            - Press footswitch C to read the numeric values.  Press pedal-toe switch on and observe lights around effects encoder, which will reveal the pedal position.
            - Press and hold tap switch for 2 seconds to save calibration.
            The pedal does not have that large of physical sweep to it so you have to get accustomed to it.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
