3300 Views 5 Replies Latest reply: Jan 18, 2012 7:31 PM by grimm26 RSS
MerlinFL Iknowathingortwo 1,524 posts since
Jul 17, 2007
Apr 12, 2012 3:49 PM
POD HD Start-up Guide
I wrote this elsewhere on this POD HD User groupd as a guide for a newbie to the POD HD experience and also hoping others who have dismissed, given horrible reviews, or returned the POD HD line of products because of the higher than average learning curve for such not-so-simple computer based gear.  Here is what I wrote and I hope it helps anyone who chooses to read it.
Out of the box I would say the HD500 is NOT gig ready.  Does it function - certainly unless defective, but I don't think that is what you meant with your questions.
I offer my findings as a long user of Line 6 guitar gear exclusively, well almost as that has changed in the past few months) but I digress.  When I first got my HD500, I was very disappointed with the very limited number of amps/cabs compared to my Vetta which has 80 instead of the 16 (now updated to 22).  I think the factory presets are mostly unusable by most players.  The following is what I recommend you take as your first steps to get to know this product properly...
Forget about all your other gear except the guitar (or guitars) you plan to use with this unit.  Get a GREAT pair of headphones, DO NOT use an amp at low volumes at this stage.  This will seem very strange to you perhaps, and perhaps to any others who read this as well, but there are very good reasons I am writing my suggestions to you in this manner and in this step by step fashion.  The end result should make everything very clear - I hope.
be VERY careful with the power supply and how you plug it in, where it sits on stage, and take care to be as gentle as possible with the power connection point as it breaks quite easily.  A replacement power supply is about $50.00. and much worse if the jack inside the unit breaks or "falls in".  Sure it's all covered by a warranty, but who wants to wait weeks for something as simple as a power supply problem?
Take the time to find and either print or simply save the expanded HD500 Users Guide online.  The manual with the unit is far too basic to be much help.
While reading through the expanded manual...use the most recent version of Monkey to upgrade the unit to the full 22 amps/cabs with the added features of bias adjustment, etc. AND the POD HD500 EDIT software!!  This requires the use of the Line 6 monkey which is FREE if you do not have the most recent version.  then connect via the USB cable to your computers HUB directly and follow the updating procedures.
DO NOT even bother with ANY of the banks of presets in the POD HD EDIT software for the time being.  I STRONGLY SUGGEST working this way instead of working only on the unit as it will save you lots of time and make many "hidden" inner workings and signal paths of the unit much clearer.  Plus the advantage of copy and paste for some sections of repeated programming is useful.
After all the updating of all the hardware and software is finished, then go to an empty USER BANK and start there with a blank slate.  Any patches from any of the presets can be simply dragged in and dropped into any slot you choose and modified if needed.  But I would want YOU to get to know which amps are there and what default settings each amp has.  Each amp has two versions PRE and FULL.  Pre is just that...the PREAMP section of whatever amp you are looking at plus the FX you may choose to add in the signal chain.  HOWEVER, if using the unit without any amp you should choose FULL as it will then model whatever cabinets and microphones you desire.  Using the headphones automatically puts each amp into this mode.  This mode is also adjustable as you will read in the advanced manual.  This is an important step BEFORE you plug into the power section of the SpiderValve.  Some sounds may sound better for your purpose in PRE and others better in FULL.  But that will come later making those choices.
Without turning the volume up too loud and cause your ears to ring, plug your guitar into the 1/4" input jack.  put on the headphones and then sit with your HD500 connected to your computer with POD HD500 EDIT running.  As you change amps, you will hear each through the headphones and give you the best possible idea of what amps will do the job you are looking for.  Also, please do not let the name alone fool you.  Just because it's a Vox/Fender, does not mean it can't be used for heavy metal, or Bogner/Mesa can't be used for warm clean sounds.  That is a combination of your guitars volume knob setting and the input gain of each amp.  Seriously spend time checking out all the sounds in FULL mode as with headphones on -as I wrote before- the unit will default to FULL anyway.
One other bit about why headphones...It is so you can hear what the amp SHOULD sound like when turned up to a volume that the amp was designed to actually run at.  And you hear much more detail with GREAT headphones this way as well.  Truly great headphones will cost about $150.00 - 300.00 and is worth the expense if you are serious about getting the most from this unit.
LEARN - TRY - ADJUST - TWEAK - REPEAT............this should go on for quite a while until you get to know each and every nuance of each amp model you wish to use.
Once all that has taken place, then simply run the HD500 into the power amp in or FX return and there you have your SpiderValve as your power amp to the preamp of the HD500.  You'll know everything you need to know to choose PRE or FULL for each patch you intend to create if you've taken my instructions seriously up to this point.
Last thing before playing out - turn your amp up to the stage volume you usually perform at and then make any final tweaks or adjustments to the HD500.
If you wish to cut some corners, there are TONS of worthwhile patches @ CustomTone.com located from this website.
If after all this you still wish to use the SpiderValve amp models and just use the HD500 as an FX pedal, that is obviously your choice.  no matter what I've written, it always comes down to what is best for the player using their gear to get the best performances possible.  You might find that you don't need the amp models on the SpiderValve which would give you much more flexibility in WHERE you place your FX in the signal chain.  Using the SV amp, you are limited to all your FX being in front of the power section unless we get into the "FOUR CABLE METHOD" and I'll leave that method for others who use it and like it.
I hope this helps you and anyone else who might read this small booklet of one persons findings on how best to work with the HD500.
Take care,
Neal
PS - you can always use your current FX pedals inside the FX loop of the HD500 which also gives you options on where to place those FX in the signal chain.  Dual amp sounds are best in my opinion as you create TWO independent signal paths that will both end up in front of your SV power section.  In other words, you can have FX in one path that are different or the same as ones in the other signal path.  And each amp can be completely different from each other for switching back and forth or combining for wider sonic possiblities.
    • spikey Just Startin' 138 posts since
      Feb 1, 2007
      Jan 9, 2012 4:47 PM (in response to MerlinFL)
      Re: POD HD Start-up Guide by MerlinFL (aka Neal Van)
      Nice Merlin, thanks.
      I might add, for all of us old school amp users, the HD doesnt work like a normal amp with a normal cab does. Let me explain...
      There are several "pre- amp" out settings and only "one" (at the moment) that can be used at a time. You pick the one you depending on where its going to be sent to. For example, studio direct mode might be sent to your board or to a DAW interface with studio powered monitors, and stacked pwr amp mode for sending to the Marshall (or DT-50) amp with your real speaker cabinet. The stacked pwr amp mode sent to your amplifier is used most of the time with speaker emulation off, and the studio direct mode is used with your choice of speaker emulation from the many that are available in the HD. That said, there is no hard set rules, use whatever sounds better to you (speaker emulation on or off wise).
      Now for the bad news... Keep in mind that while each pwr pre-amp mode is supposed to go to different amplification devices they are designed for, the tone of these preamps (Stacked Pwr Amp vs Studio Direct) do NOT change until you add the same kind of speaker emulation, at which time the tone changes between the two amp pre's... . I am hoping that Line-6 fixes this( making the different amp-pre's sound differently as they should before any speaker colorization add-on),  because using the same kind of speaker emulation on two amp-pre's that sounded "exactly" the same way "BEFORE" the speaker emulation was added, should sound the exact same again (with the added color of the new speaker emulation) when the same speaker emulation is now added to both kinds of amp pre's..., currently they do not sound the same, and this is not how real amps act.
      So can I/we live with this a while longer ? Sure...
      Is this a show stopper?  No...
      Just an FYI on what to expect so that you, like me, (who expect this to act like a real amp in this regard) wont spend hours trying to figure out what happend to your sound...
  • grimm26 Just Startin' 300 posts since
    Nov 13, 2007
    Jan 18, 2012 7:30 PM (in response to MerlinFL)
    MerlinFL wrote:
    IEach amp has two versions PRE and FULL.  Pre is just that...the PREAMP section of whatever amp you are looking at plus the FX you may choose to add in the signal chain.  HOWEVER, if using the unit without any amp you should choose FULL as it will then model whatever cabinets and microphones you desire.  Using the headphones automatically puts each amp into this mode.  This mode is also adjustable as you will read in the advanced manual.  This is an important step BEFORE you plug into the power section of the SpiderValve.  Some sounds may sound better for your purpose in PRE and others better in FULL.  But that will come later making those choices.
    Whatever you mean by "Using the headphones automatically puts each amp into this mode" isn't the case.  The headphone output gets the same signal with whatever settings you have applied as the other outputs do.  Also, PRE amp models also do get cab and mic settings, just not power amp settings (since there isn't one in the model) like bias, master, etc.
Bookmarked By (3)
