346 Views 6 Replies Latest reply: Jan 17, 2012 6:44 AM by dam1975 RSS
dam1975 Just Startin' 2 posts since
Jan 7, 2012
Jan 7, 2012 3:30 PM
Any word on a fix for error 80007104 when updating firmware
I was an early adopter of the Pod HD desktop, and I'm still running Firmware 1.0.  Tried to get everything updated today, but the firmware updater quits with error 80007104 before it can finish backing up my tones, and the install fails.
I'm running the newest drivers (7.1.3) and the latest version of the Line 6 Monkey (1.5) on an Intel Mac Pro running OS 10.6.8, 14 gb RAM.  The Pod is plugged directly into the Mac Pro, not a hub.  I've tried rebooting the Mac Pro and turning the Pod HD on and off--still get the error.  I've also tried downgrading the drivers to 5.X, but that didn't do anything.
I really want to preserve the tones I've created over the past 6 months or so.  I can back them up by hand to HD Edit, but I feel like I'm losing some of the details buried in the settings, and there's no way to test out the tones on the HD Edit until I can get it to play nice with the Pod HD--but it works only with firmware 1.01 and higher.  I tried installing a prior version of HD Edit, but I couldn't get it to install properly, despite the installer claiming that installation was successful.
Any ideas?
  • line9999 Just Startin' 2 posts since
    Feb 17, 2010
    I also encountered the same condition.
    The solution is as follows.
    The driver of MONKEY and POD is deleted first.
    And MONKEY of an old version is installed.
    Never don't use the newest version.
    Moreover, it cannot update to the newest MONKEY.
    And update firmware using old MONKEY.
    Then, it completes.
  • juhh Just Startin' 3 posts since
    Sep 16, 2006
    Looks like a common problem (see the older topics).
    Line6, where are you!?!?!?!
    Do something!
    Mar 26, 2007
    This is usually a sign that the POD cannot communicate MIDI information transfer in a timely manner for one reason or another.
    It can happen with Mac OS or Windows and is often due to either the way the computer and POD are connected or to other software or devices on the computer interrrupting good communication between computer and POD
    Definitely back up your custom presets by hand before updating your POD's firmware
    1. Make sure you have a good USB cable in use
    2. Make sure you are connecting the POD directly to a USB 2.0 port on the computer - for desktop systems, you should find rear USB ports more reliable than front ports (these might use an internal generic hub)
    3. Do NOT use any kind of generic USB hub to connect your POD
    4. Make sure you have the latest drivers properly installed on your computer for your POD
    5. Disable or disconnect non essential USB devices
    6. Try temporarily disabling anti malware software
    7. Try updating your POD in TEST/SAFE mode (for the HD desktop/500/Pro hold down the Right button on the 4 way Nav Pad as you power up)
    8. Do not opt to keep your existing patches (you should already have these backed up on your computer anyway
    Nick
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    This is a known bug with Monkey 1.50.
    When the update asks if you would like to save presets, select 'NO' and continue with the update.  This should resolve the issue.
    Or, you can download and use Monkey 1.43 and update from there to the latest.
    Regards,
    Line6Hugo
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
