438 Views 10 Replies Latest reply: Jan 9, 2012 9:44 AM by Aljosa RSS
Aljosa Just Startin' 6 posts since
Oct 25, 2007
Jan 8, 2012 3:40 AM
Pod HD500 doesn't remeber last patch settings for expression pedal
Before I start I would like to say I recently bought HD500 and this unit is really something special. All sounds are just perfect and I am really impressed by the features and all effects.  Well done Line6.
I have very strange problem with my HD500. I have two presets Clean and SOLO.  Clean is just some blackface preamp, SOLO is preset with some distortion and modulated  delays. For SOLO I assigned expression pedal to Wah and Volume.  Volume pedal is assigned to EXP1 with some min and max ranges and Wah is assigned to EXP TOE SWITCH and on EXP2. Default-initial preset state would be Volume pedal on EXP1. When pressing with toeswitch it turns to EXP2 (volume pedal off) and turns on WAH so now I can control wah. This works just fine. But then when I leave SOLO preset in EXP2 mode (Wah) and switch to CLEAN preset and then from CLEAN back to SOLO preset expression pedal is not working properly. It is turned to EXP1 and stays in wah mode which cannot be controled.
So the problem is when switching between two presets it looks like it doesn't remember state for expression pedal of previous preset. I hope you understand my issue. Am I doing something wrong?
Thanks for your help in advance.
Aljosa
    Mar 26, 2007
    You must save your patch with the defaults as you want them  - i.e. Wah OFF and Volume ON.  Then next time you recall the patch it will come back the way you want it to.
    Nick
      • silverhead Expert Line 6 User 9,592 posts since
        Apr 1, 2009
        Aljosa wrote:
        I play CLEAN preset and then I switch to my SOLO preset. I turn the Wah on with toe swtich and then I switch back to CLEAN preset (without turning the WAH off). When I get back to SOLO again it will not recall last state I left my SOLO preset. It looks like it doesn't rember that I left WAH on.
        This is normal behaviour. When you switch presets the HD reloads the new preset from its stored memory. In other words, it reloads the preset in the state in which it was last SAVED - not the state in which it was left unsaved the last time you used the preset.
        Here's what is happening: When you first switch from CLEAN to SOLO, the SOLO preset is loaded in its last-saved state - with WAH off. You then turn the WAH on but you don't save the preset. When you switch back to CLEAN that change is discarded. When you switch back to SOLO it again loads the preset in its last-saved state - with WAH off. All of this is normal behaviour.
            Apr 1, 2009
            I agree with jimsreynolds re: HD Edit vs. HD device itself. If you are using/running the Editor while switching patches then the device may load the most recent state of the preset rather than the last-saved state. That's because the Edit program is storing the most recent state in the edit buffer on your computer, and reatins this while you move between patches.
            But the HD device itself does not have this interim edit buffer. When using only the HD device you should not be seeing the behaviour you describe.
      • BigChas52 Expert Line 6 User 2,315 posts since
        Mar 12, 2007
        Your settings will go back to what you have programmed, and not the last state.  If you want your SOLO to come up with Wah on all of the time, then creat a separate SOLO_WAH patch that has Wah on by default
          • jimsreynolds Power User 2,227 posts since
            Jun 27, 43450
            To be honest I am a little surprised at how this seems to work for you
            Normally, when you save a patch it saves the state all of the footswitches (on or off) and forces this setup each time you select that patch.    You seem to be saying that your HD is remembering the state of your footswitches within a patch even when you dont actively save them. That is certainly not normal behaviour.
            Out of interest, are you using HD Edit to move around your patches or are you doing everything from the unit without HD Edit loaded?
            In terms of your original issue:  one approach is to flip between two amps in a dual amp setup.  You then put the effects you want in the same side of the chain as the amp you want.  DSP exhaustion can definitely be an an issue but, if your setup is reasonably simple, this will preserve the state of your effects within a patch as you flip between tones.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
