44444 Views 5 Replies Latest reply: Feb 18, 2013 9:06 AM by svetlosivilo RSS
nicman Just Startin' 54 posts since
Dec 30, 2009
Jan 11, 2012 1:32 PM
Pod HD500 delay and tap tempo
On the pod hd 500 how do you set up the tap tempo to control the speed of delays and other parameters?
  • gregr Iknowathingortwo 639 posts since
    Oct 26, 2009
    Jan 11, 2012 1:37 PM (in response to nicman)
    Re: Pod HD500 delay and tap tempo
    Under the speed or time parameter you will see note division symbols at the beginning (half, quarter, dotted-eighth, etc.).
      • jimsreynolds Power User 2,227 posts since
        Jun 27, 43450
        Jan 16, 2012 1:27 AM (in response to nicman)
        Gregr has supplied you with the settings that enable the tap tempo for your patch.
        The delays are all expressed either in mS (thousandths of a second) or in note divisions (as per gregr).  If you select mS then the tap switch does not do anything.  If you select note divisions then the tap switch becomes active.
        Choose a delay (say digital) and set it to quarter notes.  Now tap the tap switch in time to the music your are playing  (4 beats to the bar).   Your echo should now follow the beat.
        Now try selecting another note division (for example eighth note)eighth_note_bw.jpg
        and again tap four beats to the bar You will hear your echo change accordingly (for example with eighth note there will now be twice as many repeats for as beats).
        Make sense?
  • svetlosivilo Just Startin' 4 posts since
    Dec 6, 2008
    Feb 18, 2013 9:06 AM (in response to nicman)
    Hi
    did anyone notice that Multihead Delays on POD HD are mono?
    is that some kind of joke?
    ******* POD X3 and even XT have multihead stereo delays?
    so are multihead delays mono or i am stupid ?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
