363 Views 5 Replies Latest reply: Mar 2, 2012 10:38 AM by meambobbo RSS
Jan 31, 2012 8:01 AM
POD HD500 and one or two DT25 via L6 link
I have one question. I have POD HD500 and one DT25. I'm considering buying another DT25 for bigger gigs and stereo operation. The question is: Is there a way how to set up POD HD500 to send summed (left+right) signal if only one DT25 is connected via L6 link and send stereo signal (left to first DT25 and right to second DT25) automatically if two DTs are connected or do I have to make two sets of patches, one for mono and one for stereo scenario? I tried to search manuals but couldn't find any answer.
Thanks in advance.
Jan
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Feb 7, 2012 11:03 AM (in response to JanKupsa)
    Re: POD HD500 and one or two DT25 via L6 link
    The Setup (pages 8/9 and 9/9) L6 Link: Audio menu options are saved individual per HD500 preset/patch. So, yes... you'd want to copy your single amp patches and then re-configure them with a dual amp setting, depending on the physical setup in question. Two sets of the same patches: one for a single DT amp and another for dual DT's.
  • daveschutt Just Startin' 280 posts since
    Sep 8, 2008
    Mar 2, 2012 4:40 AM (in response to JanKupsa)
    I'm thinking of getting a second DT myself.  Have you found making doing the dual patches using only the pre's you don't run into the DSP Limit Reached as much?  I generally have a volume, wah, delay and reverb on my patches and I found with the full models I could rarely do this with the many of the amp combos.  Your answer will definitely weigh on my purchase!
    • meambobbo Iknowathingortwo 1,702 posts since
      Dec 13, 2007
      Mar 2, 2012 10:38 AM (in response to daveschutt)
      if you're already running one delay, you could add another delay with a shorter delay time instead of a reverb.  that will save you a lot of DSP.  if you just have the one short delay it can sound a little echo-ey or have a bit of a stutter to it, but with two delays it sits in the tone a little less obviously.
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
