554 Views 9 Replies Latest reply: Feb 7, 2012 2:49 PM by phil_m RSS
edstar1960 Iknowathingortwo 712 posts since
May 25, 2010
Feb 3, 2012 8:07 AM
HD500 Analog Chorus Effect does nothing after upgrade to Flash 1.4
I recently updated my HD500 to flash 1.4.
Now I have noticed that when I assign the Analog Chorus to a patch - although there is a subtle increase in volume when the effect is on there is NO EFFECT - no chorus. No matter what I choose for the settings it does nothing.
However, I have the very same effect pre-programmed in an earlier patch and that works fine - giving me a nice chorus effect when I switch it on and removing it when I switch it off.  So why does it do nothing when assigned to new patches?
Has anyone else experienced this or anything like it?  Is this a known bug? Any suggestions on how to fix?  I will probably try to reinstall the flash later tonight as my first step at trying to resolve it.
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    I don' t think anyone has picked up on this previously and 1.4 has been out for a little while now so seems odd.
    You might want to try a global settings reset before the re-flash if you have not already. --> http://line6.com/support/docs/DOC-2222
    How do you connect up your inputs and outputs?
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    The analog chorus effect only alters one side of the stereo signal (the left is wet, I believe), so depending on where you have it in the signal chain and what outputs you're using, you might not be getting the wet side of the effect.
          • daferalo Iknowathingortwo 270 posts since
            Apr 12, 2010
            Hi Edstar,
            Distortion-type effects, as well as the amps models, are mono. If you place them after a stereo one, the signal will be mono-sized. That is why you hear the chorus in the patch, despite of using just the right XLR output and the mixer settings you have. As the distortion model is off in your patch, I guess the amp model is the block which is mono-sizing your signal.
            If the stereo effect is at the end of your signal, or if it is the last effect used before the mixer panned hard, then you would get the stereo effect, and if you only use one XLR output, then you would get half of the effect!!!
            Best Regards,
            Daf
              • chimp_spanner Just Startin' 336 posts since
                Nov 7, 2008
                Yeah tbh I'm still not 100% on how the two outputs work. Like, my initial impression was that Output A and B were panned hard L and R because they represented two mono halves of a stereo whole. It wasn't until recently that I realised I could run A and B dead center, and still have one or both chains with stereo FX on them!
                  Jan 25, 2007
                  That's correct. Both path A and B are stereo paths. They only will be panned hard left and right if you set them up that way in the mixer block.
                  One thing to realize is that if you put a true stereo effect after the amp but before the mixer in a dual tone with the paths hard panned, you'll actually be losing one side of the stereo image in that path. Now there are relatively few true stereo effects in the HD500, but the Analog Chorus happens to be one of them. So if you put it after the amp but before the mixer and have the mixer panned to the right, you won't hear the effect. It's the only effect that I can think of in the HD series that has a wet/dry split like that.
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
