1568 Views 17 Replies Latest reply: Sep 13, 2012 12:46 PM by RSB63 RSS
kmcnair1 Just Startin' 17 posts since
Sep 2, 2007
Feb 12, 2012 9:04 PM
use just the 4 DT25 sounds with the HD 500
if you leave the amps or Preamps blank in the HD500 programming with HD500 EDIT is it possible to set up just the I , II, III, IV modes on the DT25. and use just those sounds and the effects in the HD500. and will it sound the same as if you were pluged directly into the amp with a 1/4 guitar cable.
    Mar 26, 2007
    Feb 13, 2012 5:28 AM (in response to kmcnair1)
    Re: use just the 4 DT25 sounds with the HD 500
    Yes.  If you leave the amp block in the HD500 unoccupied the amp defaults to Channel B and on Channel B you can do what you want with amp modelling.
    Nick
    • guagua Just Startin' 2 posts since
      Jan 31, 2007
      Feb 13, 2012 1:17 PM (in response to Nick_Mattocks)
      Is it possible to save these settings? Can I set some effects in front of the preamp and some behind the preamp?
      • Iknowathingortwo 1,667 posts since
        Jul 17, 2007
        Feb 13, 2012 1:47 PM (in response to guagua)
        Seems like...
        Saving = yes
        Before preamp = yes
        Not knowing exactly how you are planning to run this, the POST answer should be yes as well, but NO if it's just like plugging into the 1/4" jack on the front of the amp.
        I understand the concept of just using the POD HD to access the features on the DT, not sure exactly how you want your patches to work other than without any modeled amp sounds?
        Take care,
        Neal
        Mar 26, 2007
        Feb 14, 2012 3:45 AM (in response to guagua)
        Hi
        If you are using one of the POD HD units that has an FX Loop (HD500/POD HD Pro) you can employ what's known as the 4 Cable Method of connection, however, this is an analogue connection rather than by L6 Link so you'd lose amp control from the POD and you'd be using your DT-25 like a standard amp, so this may not be exactly what you want to do.
        Remember that when using L6 Link, the POD is normally your pre-amp, and also remember that the 4 Pre amp models you find in your DT-25 stand-alone are also in your POD HD500 in identical form, meaning that you don't really need to worry about the sounds from your amp in stand-alone mode as you can get them from the POD HD500 and DT-25 combination anyway, and using the POD's signal chain with some FX placed before the amp block and some FX being placed afer the amp block (when loaded with A PRE amp model) you are doing the same thing as you're asking about - i.e. placing some FX bfore the pre amp and others between the pre-amp and power amp.
        Now if you want to use Channel B on the DT-25 within a patch on the HD500, you can simply assign a Foot Switch toggle on/off to the amp model in use on the HD500 and this would mean that when the HD500 amp model is ON you would see the DT-25 Channel A LED lit on the amp's front panel, but when you switch the amp model OFF on the HD500 the DT-25 will flick over to Channel B and the controls on the amp will be active, however you can't save those DT-25 Channel B settings with the HD500 patch you're using - they are dynamic settings and you could use them to create a standard Lead guitar tone or a Clean tone for instance.
        There's lots of ways you can configure the HD500 and DT-25 depending on what it is exactly you want to do.  The HD500 is a very flexible piece of kit and can be made to fit most scenarios in my experience, and if not directly, the use of workarounds can help achieve what you want to do.
        Nick
        • pwhe23 Just Startin' 3 posts since
          Apr 7, 2007
          Feb 23, 2012 7:13 PM (in response to Nick_Mattocks)
          I can't seem to figure out which amp models in the POD HD500 correspond to the 4 on the DT-25 (I have upgraded to 1.43). Anyone know?
          • jeanpg Just Startin' 2 posts since
            Apr 12, 2012
            Apr 12, 2012 1:25 AM (in response to pwhe23)
            I agree,
            Test : with the same parameters (drive, bass,…) of preamp (exemple blackface fender preamp), the sound are really really differents between podHD and DT25. I prefer from far the DT's one!!
            So the question is…Does Line 6 give us a way to pilot the entire functions of the DT25, wich are really good ones, NOTHING MORE! NOTHING LESS!
            If not, I would be very disapointed, as many others i think…and maybe I'll have to send back this brand new amp, because it's not a finished product.
            Jul 17, 2007
            Apr 12, 2012 3:42 PM (in response to pwhe23)
            I suggest the following to get the results you are looking for...
            1. L6 Link to the DT25 from the POD HD500
            2. Call up a Blank bank of patches.  Since they are grouped in sets of four, this should work out perfectly for your desired results.
            3. Starting with bank # ?? on patch A…How about Bank 1 – patches A thru D?  Good as any if you don’t have any preference?
            4. You should see nothing but dots across the signal chain plus one larger black box (where an amp would be), and the Mixer.  Perhaps even the looper depending how you chose your display set up.
            5. Put the arrow over the larger black box, and then double tap quickly the Enter button tab on your HD500 unit.
            6. For topology 1, choose any Fender full model amp, not just the pre version.
            7. Once chosen, Click view to return back.
            8. With the new amp still with the arrow over it - double tap quickly the Enter tab.
            9. Now you should see two rows of controls.  Both rows with the exact dials as on the DT25 amp.
            10. You will be now controlling only Channel 1 which is the only channel you will gain control over the 4 topologies.
            11. Adjust the setting on the top row only for now.  This will produce the Topology 1 sound you want.
            12. Be sure to save to settings by using the save tab on the unit.
            13. Once accomplished, then go to Patch B and repeat steps 5 through 12.  Except this time, choose any of the Marshall (Brit) full amps to create Topology II.  This probably has the widest variety of difference between just the Marshall amps.  Choose the JTM-45 if you want less input gain or J-800 if you want the most gain from the Marshall amps modeled.  Or my personal favorite, the Plexi Lead 100 Brt, for a terrific middle ground between input gain and classic British tonality.  you can always put an overdrive or even a full distortion pedal in your signal chain once you've gotten the topologies you wish to have control over.
            14. Using Patch C for topology III repeat steps 5 - 12 except choose the Bogner (Bomber Uber) Full amp.
            15. Using Patch D for topology IV repeat steps 5-12 except choose the Engl (Angel F-Ball) Full amp.
              Lastly - you need to do the following to get the utmost from the DT25 amp you have...
            • After tweaking and dialing in the sound you want to come from all four topologies on channel A of the DT25 amp, you then must set Channel B to what you want all the time from that channel.  You can go to a screaming lead sound with tons of gain or to a crystal clean sound with little or no overdriven sound at all.  This is your amp, your sounds.
            • With this set up - you actually have five amps to choose from.
            • Two will have the same topology, but you will be making these channel B choices physically on the DT25 amp itself.  Once you set them, they must not get moved or it will change the sound from that channel.  Just double check the channels settings before you begin to play and you'll always have the five amps you've chosen to use.
            To access Channel B you must do the following for all four of your A-D Amp patches.
            1. Highlight the amp one each of your A, B, C, & D patches - one at a time of course.
            2. HOLD DOWN the ENTER Tab, and now you will see an "FS#" or perhaps "None"
            3. Assign this to FS8 which is the last Footswitch button next to the Pedal.  This is the FS # I always use, your choice is your choice, but I've found that keeping it the same, is much less confusing in a live performance situation trying to remember where the control for something is.  As you add FX, this will become easy to understand why.  My choice is my choice, but you can use any of the footswitches, or even you can use the Toe Switch on the pedal.  I don't do this because I use that pedal for controlling volume most of the time , but these are choices for you to make.  The right choices are the ones you feel comfortable with, not anyone else's choices.
            4. Now that you have assign a FS to the amp, you now need to see what happens when you turn it off.
            • The amp model shuts off - only the amp - and now you have a volume knob alone whose setting can be saved with your patches.  This volume knob controls the volume only of channel B on the DT25.
            • Any other FX or pieces you've added to your signal chain will now be heard through that Channel B, unless you choose to assign that same FS switch to turn off or turn on any of the FX in your signal chain that you want to work with DT25 Amp channel B at the exact moment to switch to channel B on the DT25.
            • You need to do this for each patch A thru D you create and keep in mind that whatever you choose for channel B, you can always have FX in front of the amp, or behind the amp using nothing more than the L6 Link to its fullest extent.
            • For example, you can set up channel B to be very clean.  You then could on one or more patches, have an overdrive or distortion pedal on immediately, or switch on when you want it.  This goes for any effect in your signal chain you allow to work with Channel B.
            • It's so flexible, I could write a book that would take up far too much more time than I have to give about al the choices you have in front of you with just these two pieces of Line 6 gear.
            • You also could do all these things with the POD HD500 Edit software instead of on the HD500 unit itself and then save it to a Bundle or Set List that you can store and recall anytime you have the unit connected to your computer.  You could start building your own library of patches.
            I hope this small instruction guide helps you discover what your gear is capable of doing.
            Take care and best of luck,
            Neal
            PS - if you like this guide and it does help you get what you're looking for. I'd appreciate it if you posted how this worked for you.  I can't learn more unless others write back and let me know how my suggestions or instructions worked for them.  Thanks.
            • henryswansen Just Startin' 12 posts since
              Feb 3, 43474
              May 8, 2012 3:06 AM (in response to MerlinFL)
              Thanks Neal. I don't have the DT-25 just yet but I've been doing a LOT of reading about it over the past few months. You don't get to play to this extent in the shop so it is great to get advice and feedback on how this gear can be set up.
              I knew you could switch the amp to channel b by turning the amp model off, but having the five amp per ABCD block explained in your very clear and detailed guide is excellent, so thanks.
              I have been following the 'DT sounds different to the hd' discussion for quite a while and I am interested to find out by my own ears in a few days when I get my DT25. I'm not having a go at anyone, but I have read some very comprehensive posts on these forums (maybe by MeAmBobbo, maybe Nick Mattocks, maybe another legend of the forums) that suggested that it is possible to get the same tones with the hd+DT as comes out of the standalone DT. My personal take is that if I can get good tones out of the hd+DT with the real tube warmth, I'm a happy man. Can't wait to hear with my own ears.
              Feb 3, 43474
              May 8, 2012 3:23 AM (in response to MerlinFL)
              One question though. Why do they need to be full amp models, rather than pre? I know some prefer pre and some full. Just wondering if it essential to your set up.
    Apr 12, 2012
    Apr 12, 2012 1:26 AM (in response to kmcnair1)
    I agree,
    • gridding Just Startin' 3 posts since
      Jul 4, 2008
      Apr 29, 2012 3:09 AM (in response to jeanpg)
      Hi
      Can anybody tell me what the 4 voicings on the DT 25 / 50 equal on the Pod HD 500
      If the voicings are supposed to be in the HD500 why such a problem saving the DT25 basic setup and being able to switch between the 4 basic voicings ?
      cheers
      G
      • RSB63 Just Startin' 5 posts since
        Jul 19, 2012
        Sep 10, 2012 2:18 PM (in response to gridding)
        HI,
        Up until now i though i was stupid but it's seems i'm not alone. Thanks for this. I Have the same question as i really appreciate DT 25 sounds and i'd love to pilot them from HD500 but i never achieved.
        I tryed Merlin's way but got lost, i achieved to set channel B when turn off the amp model on HD but i have tons of reverb even when DT's one is "0".
        And even doing this sound isn't the same.
        I didn't found as well the hd pre amp settings that sounds like DT.
        Anyone from Line 6 can help us on these topic ?
        I was really impressed with the amp ( and still be) but i'd love to use it with HD in this way cause i'm frustrated on this part .
        Thanks
        • gtrman100 Iknowathingortwo 479 posts since
          Jan 24, 2007
          Sep 10, 2012 2:28 PM (in response to RSB63)
          You have tons of reverb because the reverb control on the DT is always active, and independent of the HD500's reverb. Turn down the reverb on the amp, and you can control it from the HD>
          Jul 17, 2007
          Sep 10, 2012 3:30 PM (in response to RSB63)
          RSB63 wrote:
          HI,
          gtrman probably answered the reverb question 100% on the money.
          I'm sorry my instruction i laid out step by step were confusing to get you lost.
          I then suggest the following to all those - which are far more than I'd have ever guessed - I suggest using the POD HD units in the following way since those who are in love with the DT amps sound without the HD unit in front or L6 Linked.  I suggest one of these two options...
          1. Use the POD HD unit as just an FX unit and just work with the DT amps 4 modes by plugging the HD unit into the 1/4" input in either the high or low input gain jack and got from there.  You'll need a separate but very simple A/B footswitch to change the DT amp from channel A to channel B.
          2. Other option is to insert the HD unit into the FX loop and make all the appropriate adjustment to both the send, return levels on the DT amp as well as the in/out level on the HD unit.  Still need the simple A/B switch though.
          If these options aren't good enough or don't do what anyone who loves the direct sound of their DT amp but can't get the same in conjunction with the HD unit connected or L6 Linked.  I'm out of suggestions and then would have to suggest waiting until Line 6 employees (or best of all - the actual designers of both these units.
          Do ya think those two (or more) groups of people worked together literally comparing how the units each group working on works together in a physical real world test, or did they just send memos back and forth between the halls @ L6 HQ?  Never once having hooked them together before putting all this gear out into the hands of the public?
          It also makes no sense to me, that if the digital part of the two unit's "guts" are perhaps different, yet supposedly should react/sound the same...then why is it all these posts are here saying no one -or hardly anyone- can get the same sound plugging direct to DT they love yet they cannot plug into HD-L6 Link-DT and get the same result?
  • rucademoura Just Startin' 30 posts since
    Apr 12, 2012
    Sep 10, 2012 3:49 PM (in response to kmcnair1)
    I have some patches in HD500 via L6 link, with no amp selected, working with chanel B, and have no problems at all!! The sound is the same, and I control everything on DT25 chanel B! Of course I use always the same amp sound in those patches, the only thing different are the effects on HD 500! Other amps (patches) , I use chanel A(HD 500). I understand lots of you likes the DT 25 standalone sound, but it's possible to a closer closer sound in HD! If we have both, let's tweak the gear to get our sound! Chosing the right amp ( pre-amp), tweaking the pre-amp model, NO CAB!!!, routing carefully the effects, will make you sound great! For exemple i route everything to left and pan center, then i mute the right chanel on the mixer! It worked for me! the 1M input for me worked also! Normal mode! the AES/EBU cable makes a huge diference in my case! I remember one gig i forgot it and used a normal XLR -----my sound was not the same (harsh)...
      Jul 19, 2012
      Sep 13, 2012 12:46 PM (in response to rucademoura)
      Thanks all for your answers, i ordered a new AES/EBU xlr maybe it's due to this cause i took one of my band. I'll get it soon and come back to you. Thanks for your time. You were right for reverb, i thought putting it to 0 on channel B was enough but when i cut it from channel A it went a lot better as on HD.
Bookmarked By (2)
