Feb 12, 2012 11:00 PM
HD500 tone sucks when not using amp models
Like (0)
ok so i bought a hd500 to go with my Tyler variax.
problem started as soon as i plugged it in.....(Variax into Variax input using the line6 supplied cat5 ethercon cable and out to the input jack of my Fender Blues Dlx from the 1/4 inch output jack of the hd500)
when i turn on the tuner (i guess by-passing the HD500's modeling engine) the guitar sounds great, full bodied, clear, clean etc just like plugging directly into the amp.
BUT as soon as i turn the tuner off I lose all the definition and tone, muffled and weak (and that is before I insert any amp or effect blocks so I was expecting the signal to just pass through without any coloring of the tone).
it sounds like c**p.
I can get it sounding better by using an amp model in the signal path but i kinda like the natural sound of my tube amp.
i just want to use this HD500 for FX and Variax control.
am i missing something?
Please help!!!!
Hmm that is a little strange. The only thing I'd suggest is checking that your impedance controls aren't defaulting to their lowest setting, as that would have the effect of dulling the sound. I find a setting of 1m or 3.5m really brightens things up. Although I can't see why or how that setting would have been changed. Still worth investigating though. You can get to it by pressing and holding "View" and going to page 3/9.
Ok Success
After much digging and hair pulling i finally found what was zapping the tone!!!!
It was in the global output settings..... the high pass and low pass filters were set to 50% thereby cutting high and low frequencies by half leaving the guitar sounding all middley and nasal. I set both filters (attenuaters) to flat and hay presto.... a full frequency guitar sound and without the need to use any amp modeling.... oh my goodness I am a happy chappy now.
Now....
CAN ANYONE TELL ME WHY LINE6 WOULD HAVE THE HIGH AND LOW ATTENUATERS SET AT 50% AS A DEFAULT??????
It just don't make sense
please let me know what are the 'flat' setting you have adjusted to. it would be a great help
Thanks
Pratik
if you press and hold the View button you enter the system setup menu.
Go to page 4 (using the up and down keys to the right of the view screen) and you will be in the output setup section.
multi function knob 2 will attenuate the low frequencies and 4 will attenuate the Highs.
I found that they were both set to 50% which means they cut the volume of highs and lows by half.
I am a professional sound engineer and we refer to these as high pass and low pass filters (a high pass filter will cut all frequencies below a set frequency point allowing all frequencies above that point to pass unaffected and a low pass filter will cut all frequencies above a set point and allow lower freqs to pass in the same way.
if you turn knobs 2 and 4 respectavly either fully clockwise or counter clockwise (i forget which but it is just a matter of trying one and if it dont work go the other way) you the display will say Flat. at this point the highs and/or lows will pass freely without any cuts (or attenuation)
i hope this helps you as it did me
Colin
Thanks Colin, u saved a day
