238 Views 3 Replies Latest reply: Feb 15, 2012 6:22 PM by Mr_Arkadin RSS
Foley1Kanobi Just Startin' 2 posts since
Feb 16, 2010
Feb 15, 2012 2:04 PM
Pod 2.0, Windows 7 - 64-Bit Connection questions...
Hi there, I bought a Pod 2.0 (Newer model) about 2 years ago, and i've never been able to set it up working with the laptop, Initially, I was told that i needed a MIDI to USB lead to be able to record from the Pod onto my laptop. So i went to maplins and the guy told me that this was the lead i needed
http://www.maplin.co.uk/usb-to-midi-adaptor-lead-48612
So i bought that,  and then i tried getting it to work with my laptop - no joy. I think the reason for this is that i can't seem to get the manufacturers drivers or something..
Anyway i left it at that for a bit and today i went into our local recording studio and the guy there told me that i needed to get an external sound card to be able to connect it to it - he recommended
http://www.thomann.de/ie/maudio_fast_track_pro.htm
The idea is that i want to record myself playing and if possible also singing - but i'm not to worried about the singing as that can be done via mic, although i do have a peavy mic that would be nice to have working aswell.
So, Whats my best bet??
Any or all help is appreciated
Thanks in advance..!
  • Mr_Arkadin Expert Line 6 User 2,379 posts since
    Jan 25, 2007
    MIDI cannot record audio - it is a data-only protocol designed to allow instruments from different manufacturers to talk to each other.
    Althougha separate audio device is a good recommendation, how about trying to use you existing set-up? Most computrs come with a sound card built in. Admittedly the input sockets are usually 3.5mm, but are usually stereo. Check what type of connector you have. If it is a 3.5mm stereo LINE input (this is important - it cannot be a mic input), then something like this will suffice:
    http://www.amazon.co.uk/3-5mm-Stereo-6-35mm-Audio-Cable/dp/B0034DSUMK
    The black jack goes to the Pod left output and the red to the right, the 3.5 into your line input on your audio card. Your audio card may have different connectors or no line input, so a separate solution as recommended by the second guy may be the best way to go.
    If you want to sing at the same time then you will definitely need a more sophisticated audio device than what is built into your computer, even that Fast Track will only allow you to record your mic and one (left/mono) output of the Pod - if you want the Pod in stereo and also be able to record your mic you will need at least three inputs (so you'll probably need to look at a device with four inputs).
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
