337 Views 0 Replies Latest reply: Feb 17, 2012 7:50 AM by meambobbo RSS
meambobbo Iknowathingortwo 1,702 posts since
Dec 13, 2007
Dream Theater/Petrucci Patches
I tried for a while to dial in a GREAT DT patch.  Source material was the A Dramatic Turn of Events tone, as well as the mark V youtube vid: http://www.youtube.com/watch?v=owwRxl1hKaI See 4:15
Here are the results:
http://foobazaar.com/podhd/DTPatches/
I like the middle one the most - http://foobazaar.com/podhd/DTPatches...l_xxl_57on.h5e
I spent the most time dialing that one in.  I even veered from my standard approach of using identical settings on both amps to get it to sound better - used only bass from the XXL and dialed down mids on the XXL - the bass/mids mixed equally from both was creating interference and getting a stale tone.  I also varied the hum setting.  The lower setting on the XXL side gives the tone less of a percussive growl, which makes it a little spongier which is where it should be, but the Treadplate side needs the aggression.
You can fit a noise gate (unfortunately not a hard gate) in front - but i found it too detrimental to the tone to be worth it.
If you want some space to the tone, remove the Parametric EQ with the really high Q setting (fizz remover) and add a delay - you don't have enough DSP for a reverb.
If you want a reverb for a more authentic tone, use the single amp tone - http://foobazaar.com/podhd/DTPatches...e_tread_on.h5e Just be forewarned it sounds a little noisier and has less punch.
hope you enjoy these tones - i'll post a demo hopefully this weekend
