Feb 21, 2012 6:40 PM
HD500+DT25+DVI+Variax Preset Outputs, Acoustic going out to monitors and not DT-25
Like (0)
What I thought I'd be able to do when I bought this was to be able to assign the outputs on the HD500 on a preset basis. My main issue is using the acoustic guitars on my JTV-69. It's farily easy to set up the guitars to change with the presets and amps but I want to get the acoustic guitar out of the HD500 to monitors and not going into the DT-25 by changing the preset. Is this possible?
use the send of the fx loop
+1 Stumpout
Just take the FX Loop send out to the board (or DI Box). Include an FX Loop block in any patch where you want to use your acoustic and make sure it is switched on. If the FX
Block goes before an amp model (or you switch the amp model off) then it should be unaffected by modelling or output modes. If you want the amp modelling in there for acoustic guitar then be aware that you cannot have Studio Direct at the FX Loop but also use one of the Power Amp/Front Modes into your amp. You must choose between the two.
How about using one of my patches I created for the Variax guitar as well as the POD HD500 with or without the DT amp connection. If you use one of my Acoustic patches for the HD500 and you're L6 linked to the DT, then it WILL sound very nicely acoustic. Even though the amp has no tweeter or horn, it still WILL sound very acoutsic, BUT the BONUS is that while still using the same signal chain with the XLR out the back of the DT amp - you will GET the Tweeter/Horn sound from the PA speakers for those harmonics and other overtones not able to be reproduced properly by a speaker only.
Why hassle with extra patches if you don't need to?
Here's the link to my list of uploads. The POD HD500 patches start on page 3.
http://line6.com/customtone/profile/MerlinFL/
I hope this helps make things real easy for you and anyone else who might read this method of connecting gear to a PA system.
Take care,
Neal
PS - if you like it, or not, I would appreciate any feedback. I will always help me become better at what I do with my gear and hopefully then share it with the rest of the Line 6 community.
Brilliant advice. Works a treat, thanks for your help. I'm using a JTV 59, DT25 and Marshall AS100 Accoustic amp. Cheers Tony
