Feb 25, 2012 9:09 AM
M13 options for playing along with songs/backing tracks?
Like (0)
I have an M13 connected via 4CM to a Fender HRD (will have a Marshall JVM 205C soon).
I'd like to figure out a good way to play along to backing tracks. Any ideas? I'm open to adding a piece of gear if needed.
No ideas?
Given the limitations of all the input options of the gear you mentioned, you'll need an audio signal merge device to offer the possiblity to insert two inputs back into the FX Return jack of the Fender Hot Rod Deluxe amp.
Like a Y-Adapter (a bit shoddy, but it'll work). You'll send the M13's Output/Cable #4 and then plug your backing track device's output into the other input jack. It'll be a mono signal, though.
