145 Views 2 Replies Latest reply: Mar 23, 2012 5:36 AM by laplayantonio RSS
Istrydhil Just Startin' 5 posts since
Nov 14, 2010
Feb 25, 2012 3:17 PM
Problem to import midi files to midi memo !
An error occured when i try to import MIDI files to MIDI Memo on my iPad through iTunes files sharing. A message notices me that only files created in MIDI Memo can be imported ?! Why ? Is it a limitation or a bug ?
Thanks for replying,
Best regards,
Laurent
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Mar 5, 2012 3:18 PM (in response to Istrydhil)
    Re: Problem to import midi files to midi memo !
    Q: Can I copy a MIDI file from my computer into MIDI Memo Recorder?
    A: This can be accomplished via iTunes File Sharing with the MIDI Memo Recorder app. Alternatively, you can simply play any MIDI file out your computer's MIDI interface directly into MIDI Mobilizer or MIDI Mobilizer II, and record the data in our MIDI Memo Recorder app as a new MIDI Memo. This will capture and time-stamp all of the data, and the app can also play it back exactly as it was received
    Q: What MIDI data can the MIDI Memo Recorder app record?
    A: MIDI Memo Recorder will capture and record all MIDI data that can be stored within a Standard MIDI File, which includes all performance information (notes, controllers, pedals, pitch bend, after touch, etc) as well as any System Exclusive data (usually the parameter values of a keyboard or effect unit's sounds and settings). It does not record System Real Time messages (which include Active Sensing, MIDI Timing Clock and Start/Stop/Continue), as these are not part of the Standard MIDI File format.
    All received MIDI messages are time-stamped to an accuracy of one millisecond (1/1000 second) in order to preserve very accurate timing for all MIDI events.
    If you can not import the file into the iTunes File Sharing it is most likely because the file is not a standard midi file.
  • laplayantonio Guru 2,435 posts since
    Sep 26, 2006
    Mar 23, 2012 5:36 AM (in response to Istrydhil)
    RE: Problem to import midi files to midi memo !
    Hello. We haven’t heard back from you, so we're going to assume your question has been answered. If it has been answered, please consider awarding points to whoever was helpful and/or answered the question so they get the formal recognition.
      In the event your issue has not been resolved, we have generated a support ticket for you so we can continue to communicate. Should you need further assistance, please respond to the ticket. With us talking via the ticket, I will mark this thread answered.
      Q: What is a support ticket?
      A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link to the ticket when a Line 6 Support Representative responds to it. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support. Also, in your account, click My Account, then click Support Tickets to view the support ticket. Here’s a shortcut: http://line6.com/account/tickets/view/.
      Please note: Sometimes support ticket notifications will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host, and also that your email account is receiving messages at all. You may also consider adding Line 6 to your safe senders list.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
