212 Views 7 Replies Latest reply: Feb 27, 2012 8:55 AM by meambobbo RSS
dleted Just Startin' 3 posts since
Aug 13, 2011
Feb 25, 2012 7:48 PM
HD500 Loud Buzz
Hello!
I have an annoying buzz issue with my HD500 that is driving me crazy and thought I might find some answers here. First let me begin by saying that I have new cables, old cable powered monitors, headphones, connected to a computer via USB, not connected, plugged into a grounded circuit, also tried undgrounded. and it buzzes no matter what. The buzz it generates is LOUD but my MXR Smartgate kills it out for the most part. The guitar is my Jackson DKMG with EMG 81/85 active pickups. I usually run highgain and this only worsens the issues.
If the guitar is plugged in and volume is all the way down, no buzz at all. If my guitar cable is unplugged from the HD500 also no buzz. The buzz only happens when the guitar is plugged in and volume it up. It doesn't stop if I do things like touch the strings, or the HD500. It does however change in intensity if I change what direction I stand in relation to the POD.  As in if I face the unit I can minimize the buzz, if I turn 90 degrees it gets really loud. I also tried it in a part of my house that has complete new electical wiring and grounding. What is more odd is that the buzzing is most intense when headphones are used. Doesn't matter which headphones are used either.
Any ideas are welcome!
Thanks,
Zack
  • meambobbo Iknowathingortwo 1,702 posts since
    Dec 13, 2007
    Feb 25, 2012 9:10 PM (in response to dleted)
    Re: HD500 Loud Buzz
    sounds like your guitar's electronics cavity isn't sheilded or something isn't grounded.
    • jimsreynolds Power User 2,227 posts since
      Jun 27, 43450
      Feb 26, 2012 8:15 AM (in response to meambobbo)
      Re: HD500 Loud Buzz
      +1 Meam.  Active pickups are generally very quiet.   It sounds like dicey wiring to me.
      Have you tried another guitar?
      • birro Iknowathingortwo 172 posts since
        Jun 27, 2007
        Feb 26, 2012 9:02 AM (in response to jimsreynolds)
        Re: HD500 Loud Buzz
        +1 meam and jim
        Another thing that came into my mind is the switch nearby the top of the expression pedal, the "Guitar In". Have you tried setting it to PAD in order to reduce the signal provided by the high gain pickups you have? But have in mind that meam and jim's advice are definitely the way. It looks like a grounding issue from the guitar, not the HD500 at all.
  • leegoodrick Just Startin' 11 posts since
    Mar 14, 2009
    Feb 26, 2012 9:13 AM (in response to dleted)
    Re: HD500 Loud Buzz
    Tried a fresh battery for your EMGs?
