217 Views 3 Replies Latest reply: Mar 17, 2012 9:24 PM by MetalMarysia RSS
MetalMarysia Just Startin' 4 posts since
Feb 27, 2012
Feb 27, 2012 5:14 PM
X3 Live Pedal Volume/Wah switching problem
I got my local music store to order in a used X3 Live from another location, but before I bought it I tried it out. At first there seemed to be no problem with the pedal, then I went in and changed the type of wah sound on a patch. I don't think I did anything else in there, but I'm not very familiar with the interface (my last Pod was an XT). So it was fine, tried a few wah sounds, and did not save any changes, switched patches, then noticed weird things happening with the pedal when switching from volume to wah and back again.
I'd switch to wah then back to volume, and suddenly volume acts as a wah. Then back to Wah and it's either acting as volume or a weak sort of mix of the two - like a wah pedal that quiets down when flipped down. This happened on various patches in different banks.
There didn't seem to be any logic to it -- it felt more like a defect with the pedal or computer, not a feature I'm not understanding. I don't really think it had anything to do with me tinkering with the wah types either.
I didn't buy it, and the assistant there agreed that it's a defect. But has anyone had this problem? Or, is it not a problem, but some setting I (and the assistant there) don't understand?
Thanks!
    • silverhead Expert Line 6 User 9,592 posts since
      Apr 1, 2009
      Feb 29, 2012 9:09 AM (in response to MetalMarysia)
      Re: X3 Live Pedal Volume/Wah switching problem
      I suspect it is normal behaviour and not a device problem. I think you are right about it being something that neither you nor the assistant understand.
      It is quite possible to create presets on the X3L that cause the pedal movement to have the results you describe. In order to answer with certainty, an experienced X3L user would have to literally inspect the preset, note the pedal assignments, and determine whether the behaviour is predicted by the assignments. As a novice user the behavior would seem strange and a little weird and illogical because you might expect the pedal to behave the same way at all times. It doesn't - and that's normal as long as the preset is designed to make it behave differently.
      So while I expect the previous owner defined the presets this way, and there is no problem with the device, I would still recommend that you only purchase it if you have a return policy that will give you a full refund in the event that there is a device problem. I think it would require at least several days for you to get familiar enough with the device and the flexibility of pedal assignments to satisfy yourself on this point.
      If you want, you can download the X3L User Guide and investigate the pedal assignment options. You might be able to get an understanding of how a certain set of pedal assignments could cause the behaviour you observed. Go here:
      http://line6.com/support/manuals/
      Then select All Products in the top right corner, select hte X3, and download the X3 Advanced Guide.
