356 Views 9 Replies Latest reply: Mar 21, 2012 10:28 AM by Line6Don RSS
n-tarren Just Startin' 5 posts since
Aug 15, 2007
Mar 2, 2012 1:36 AM
How can I check if my UX1 is dead?
My Toneport UX1 has stopped passing almost all audio through. Is there any way to reset it or do I need to replace it?
My setup:
iMac - 2Ghz Intel Core Duo - 2Gb Ram, 300 Gb HD (50Gb free)
Mac OSX 10.6.8
Audio Out and In set to Toneport UX1 in Sound preferences - Volume set to 50%
Mac "sees" a Toneport UX1 on whichever USB Bus I plug it into.
All software reported as up to date by Monkey. Both Drivers and USB Firmware recently updated.
Toneport Plugged in shows green power light and can be "seen" by Line6 for software updates refreshes etc.
Pair of M-Audio speakers worn direct when plugged in to the Mac, but via Toneport I only get an initial loud 'click' when I plug it all together or reboot the Mac. Same with Headphones.
Then - nothing either from iTunes or PodFarm 2.5 etc.
Have I missed something or is time for the bin?
  • arislaf Iknowathingortwo 426 posts since
    Sep 8, 2010
    Mar 2, 2012 2:33 AM (in response to n-tarren)
    Re: How can I check if my UX1 is dead?
    Try to use the UX as your main sound card at all aplications, (movies ,music etc.) and please let as know.If it is working like this, then is definetly a problem with the sofware (podfarm etc.) or with the cable of the guitar, the guitar ,etc.Since the UX is recognised by the monkey, means it is still alive, though.If after this check it is still with no sound , then I run out of ideas.
    BTW, try to reinstal all the drivers of the UX at your computer.
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Mar 2, 2012 8:23 AM (in response to n-tarren)
    Try it on another computer.
    Also make sure you are using the latest drivers?
    http://line6.com/software/
    Feb 20, 2007
    Mar 3, 2012 6:38 AM (in response to n-tarren)
    Just to be clear, are you connecting you headphones and/or monitors directly to your UX?
    Is thre a pc you can try it on?
    And try different USB cables and all USB ports.
    And give this a read just eliminate another possibilty.
    OSX Authorization issues:
    try using the following instructions:
    close out of all Line 6 software first. Then, open a Finder window and select your [User Account] on the left (with the "home" icon) and look for the Library/Application Support and see if there's a Line 6 folder in there.
    Highlight the Line 6 folder and do a "Control + Click" on it; then choose "Get Info" in the submenu that pops open. Go to the bottom of the window and check the "Sharing & Permissions" box. If the Priviledge is set to "Read Only" on your Mac, this is the culprit. Change it to "Read & Write".
    Then, re-launch License Manager and de-authorize your Mac. Re-Authorize it again.
    • Line6Don Line 6 Support 5,274 posts since
      Mar 14, 2011
      Mar 13, 2012 11:45 AM (in response to Triryche)
      After reading through the thread, it was never clarified whether or not the UX1 was assigned as the system's sound card.
      For tutorials on setting up your Line 6 hardware as your computer's external sound card, reference the links below:
      Windows XP
      http://line6.com/support/docs/DOC-1452
      Windows Vista - 7
      http://line6.com/support/docs/DOC-1453
      MAC OSX
      http://line6.com/support/docs/DOC-1454
      After you assign the UX1 as the system sound card, check all connected cables to ensure they are connected properly and try again to output audio using a program like iTunes.
        Mar 14, 2011
        Mar 21, 2012 10:28 AM (in response to n-tarren)
        I would suggest trying to set the UX1 up on another computer system, this will help to see whether or not the problem is based with your UX1 or your computer itself. Follow the instructions below to setup the UX1 on another computer system to test and see if you can receive audio playback from the outputs of the UX1:
        Download and install the latest Line 6 drivers for your operating system:
        Windows Drivers 4.2.5.1:
        http://line6.com/software/readeula.html?rid=4399
        MAC Drivers : 7.1.3
        http://line6.com/software/readeula.html?rid=4321
        Once the drivers are installed you will need to install the Line 6 Monkey application from the links below:
        Windows Line 6 Monkey 1.51:
        http://line6.com/getrelease?rid=4618
        MAC Line 6 Monkey 1.51:
        http://line6.com/getrelease?rid=4619
        Once Line 6 Monkey is installed, remove any additional unnecessary USB and firmware devices from your computer when troubleshooting this issue. Make sure to connect it directly to a USB port and not a USB hub, extension, or keyboard of any kind, preferably connect it to a USB port on the rear of computer. Try using additional USB cables and every USB port available until you are able to launch Line 6 Monkey and detect the device.
        After Launching Line 6 Monkey apply any updates that are available until you have a green check next to each component.
        After finishing this, use the instructions I provided to you previously to assign the UX1 as the system's sound card. Test to see if you can receive input and output of audio. If the UX1 works properly on the second system, that indicates the trouble is with your computer. If the UX1 does not work on the second system it indicates the problem is potentially with the UX1 hardware itself.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
