Mar 3, 2012 1:25 AM
Win7 / Studio UX1: Amp Models still not working in POD Farm 2.51 and Reason 6...
Like (0)
this is a follow-up to thread http://line6.com/support/thread/76097
copy of original thread:
Hi there,
I have a studio ux1 with several model packs installed.
factory add-ons: fx junkie / POD Farm 1)
purchased: bass ext. / power pack / metal shop / collector classics / POD Farm 2 / Propellerhead Record Add-On
I was using it with no problems at all on my old vista computer together with propellerheads record.
the podfarm also worked perfectly.
Right now i want to setup reason6 & studio ux1 on my new windows 7 computer.
Specs in short are:
Intel Core i7 860 @ 4x 2.8GHz / 8GB RAM
System HD: OCZ Vertex SSD
OS: Win7 Pro 64Bit SP1
Novation Remote49 SL MkII (Automap 3.7.4)
Studio UX1 (drivers 4.2.4.9 / firmware 1.01)
Line6 Monkey 1.43
License Manager 1.01
POD Farm 2.51
Propellerheads Reason 6.0.1 (UX1 ASIO)
So far the amp models do not work at all in POD Farm 2.51 standalone and Propellerheads Reason 6.01.
the sound does not change.
Reason 6 freezes for at least half a minute when i try to add a line 6 amp to the rack.
afterwards it displays the amp in the rack but the sound stays the same.
I can't even access the free amp models that came with propellerheads reason.
I also have problems loading songs created with propellerheads record that have amps in the rack.
POD Farm 2.51 standalone does not freeze when changing gear and always says i have all the needed models installed for the preset,
but also does not change the sound.
Both, the computer and the device are authorized with the License manager 1.01.
Everything shows up correctly in the License Manager.
i think the other thread is closed.
so i opened this one instead.
hi again,
sorry for the delay.
i was too busy at work to check it out sooner.
i tried deauthorizing / reauthorizing just the device.
i also deinstalled everything once more and installed everything again in correct order.
i decided to install both pod farm 1.12 & 2.51 this time.
this time it behaves nearly the same.
the pod farms are not working.
the loading of the program and the presets take ages.
the sound is not changing. i only have a dry signal.
with reason ot got a little worse than before.
when i try to load an amp now
it keeps saying that there is a problem with my line6 hardware.
i also tried removing the L6TWXY folder manually.
that actually worked once.
i had a brit standard amp in reason.
but that didn't last for long.
the next time i started reason it was like before.
i tried to remove it again, but this time it didn't work.
so now i am stuck with no amp models in podfarm 1.12 or 2.51 and reason6.
thanks in advance for any help.
regards
meik
hello
please try the troubleshooting in http://line6.com/support/docs/DOC-2304 under "3. Amp Models no longer available in POD Farm 2.0 or older after installing POD Farm 2.5"
line6antonio
Hello. We haven’t heard back from you, so we're going to assume your question has been answered. If it has been answered, please consider awarding points to whoever was helpful and/or answered the question so they get the formal recognition.
In the event your issue has not been resolved, we have generated a support ticket for you so we can continue to communicate. Should you need further assistance, please respond to the ticket. With us talking via the ticket, I will mark this thread answered.
Q: What is a support ticket?
A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link to the ticket when a Line 6 Support Representative responds to it. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support. Also, in your account, click My Account, then click Support Tickets to view the support ticket. Here’s a shortcut: http://line6.com/account/tickets/view/.
Please note: Sometimes support ticket notifications will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host, and also that your email account is receiving messages at all. You may also consider adding Line 6 to your safe senders list.
