1282 Views 38 Replies Latest reply: Mar 9, 2012 11:04 AM by alfmetal70 RSS
alfmetal70 Just Startin' 104 posts since
Feb 3, 43473
Mar 4, 2012 4:55 AM
POD HD500 Details guide
Hello, I did a little guide of some things that I think nobody talk before and are part important of the sound.
Grettings from Chile!
  • mazuwa Iknowathingortwo 371 posts since
    Jul 7, 2006
    Mar 4, 2012 5:12 AM (in response to alfmetal70)
    Re: POD HD500 Details guide
    Thank you for sharing your experiences with the HD500.
    I just want to add:
    - Concerning the Recording Volume over USB the Master Volume knob is level independent.
    - Sometimes the sound on different banks may sound different because the Line6 editor in the moment does not feature all parameters, e.g. the Guitar-In Resistance. When Input set to Preset instead of Global, they also may sound different.
    • PaulBateman Just Startin' 82 posts since
      Mar 19, 2010
      Mar 4, 2012 7:35 AM (in response to mazuwa)
      can i ask about that while its here... i dont really understand the values there... it defaults to 1m i think.... but what does that value refer to and what determines the best setting?
      • silverhead Expert Line 6 User 9,592 posts since
        Apr 1, 2009
        Mar 4, 2012 8:12 AM (in response to PaulBateman)
        On page 2.5 of the latest HD500 Advanced Guide you will find a listing of the impedance values for all HD500 FX models. These are the settings used when the In-Z parameter is set to "Auto". The setting applies to the first FX model that appears in the signal chain.
          Mar 19, 2010
          Mar 4, 2012 9:52 AM (in response to silverhead)
          so its an amp by amp thing? i thought it was set based on the guitar being used..
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Mar 4, 2012 8:10 AM (in response to alfmetal70)
    I don't agree with your assertion that not having something in all the effects blocks will cause you to "lose frequencies". I think there must be something else going on that you're experiencing. I'm also not sure what you're meaning in your pictures by labeling the "inside part" and "outside" part. I think you may be experiencing some of these tonal differences because of the way HD500 handles the input signals and the fact the some effects are true stereo and some are not.
      Mar 19, 2010
      Mar 4, 2012 9:59 AM (in response to phil_m)
      i think its just a matter of having alot of effects are shaping the tone to his liking...
      i reflashed my pod last night and found my user1 setlist filled with presets that werent there before (weird..lol) but actually found a bunch i liked.... one was a clean tone that had all blocks used and it sounded great! alot fuller then anything i made previously.. simply because of the multiple EQ's etc i think
      i wouldnt think its just filling the blocks that causes that, but the EQ's etc are doing their job... plus like you said, those routing options are there for a reason..
      as more of a geek then a musician, im loving that i constantly find new tricks and methods even months after i bought it..
        Jan 25, 2007
        Mar 4, 2012 4:24 PM (in response to alfmetal70)
        I'm not doubting that you're hearing some difference. I'm just saying the reason behind it appears to be with the fact that the way true stereo effects work in the signal chain, and the way the HD500 deals with mono and stereo signal splitting in general, seems like the explanation to me. I don't think that a bypassed effects block and a blank one will sound different in all situations. There are certain ones in which I would see they would, though. For example, the studio EQ model is a true stereo effect, and I'm not sure what the delay is you have there, but I think that could be the explanation for what's happening with your tone.
        A friend is actually borrowing my HD500 right now, so I don't have anyway to test this out for myself at the moment.
        Jul 7, 2006
        Mar 4, 2012 8:36 PM (in response to alfmetal70)
        It has to do with the mixing (level + pan) and the way you give the signal to the upper and lower signal chain, also considerung stereo effects. It is normal that you get the impression that with different volumes, as with real amps + stomps, the sound becomes brighter or fuller the louder they are. Same to effects that split to stereo (chorus) or convert the stereo signal to mono again (compressor).
        The sound difference between picture 3 and 4, which show only deactivated blocks in contrast to empty ones, I cannot completely explain, but I can hint on deactivated blocks also need processor power, in contrast to empty blocks that do not use power.
  • meambobbo Iknowathingortwo 1,702 posts since
    Dec 13, 2007
    Mar 4, 2012 8:31 PM (in response to alfmetal70)
    dude, i don't even know where to begin with this, but I'm pretty sure most of this information is flat out wrong.
    if you are not in studio/direct output mode, the mic selection doesn't change the tone at all.
    if you're not using the line 6 link to a DT-XX amp, the class A/AB, topology, and pentode/triode selections do nothing.
    if effects are off, they don't do anything.
    channel A and channel B do not have different tones, only different routing.
    channel volume doesn't have to be 25% less or you get clipping - that depends on your patch and the amp you're using.  same with your mixer settings.
    Master Knob's setting shouldn't always be 60% - it should be as high as possible without clipping external gear.  that's proper analog gain staging.
    100% drive for the high-gain models is likely way too much gain.
    I assure you moving the EQ knobs in the amp models aren't a bad idea in general.
    22k input impedance is going to get you a very loose feel and a darker tone, pretty much the opposite of what you usually want for a high-gain tone.
    the order of the effects in the chain certainly does matter, but the order of the effect when viewed in Edit does not.
    i haven't studied all of these things in detail, but i'm 99% a lot of the tonal differences you're hearing is just your imagination.
      • jimsreynolds Power User 2,227 posts since
        Jun 27, 43450
        Mar 5, 2012 3:56 AM (in response to alfmetal70)
        I don't want to be negative about your work because I think anything that explores the darker corners of setting up tones is ultimately good for everone.  However, I too have doubts about some of what you are saying.  I will be honest and admit that I have not sat down and tested all of your scenarios but some of it just doesn't sound right.
        I agree with Meambobbo - the Class/Topology/Mode settings should only have an effect on the DT Amps - which make a feature of being able to reconfigure these parameters.  You can see the clear 'DT' logo to the left of them in the pic below.  With an HD Only:  nothing should actually happen.
        In my experience making a change to any of the amp parameters causes a momentary dropout and I will admit that for a while this made me think that things were changing when they actually weren't.  For example, with my HD in Combo Power amp mode I used to beleive that changing the Mic Models was actually doing something subtle .... it wasn't !   When I changed to Studio Mode I could really hear the difference.
        The only way to really be sure here would be to:
        • Hookup the HD to a PC with a good audio recorder software
        • Set the Looper to Pre
        • Record a few riffs into the Looper
        • Record the looper playback with the DT Settings (or whatever you are testing) in one position
        • Record the looper playback with the DT Settings in the other position.
        • Compare the two recorded waveforms.
          Mar 19, 2010
          Mar 5, 2012 4:35 AM (in response to jimsreynolds)
          one thing i will throw in.... i do find the tone changes in a very subtle way sometimes... maybe there is an explanation tho...for example
          i'll record a simple loop using one patch... then ill switch to a different patch and i hear a change to the recorded loop.... output settings are globally set so i dont really know why the sound changes.. its not set to pre or anything obvious like that... my experience is limited to say the least but its almost like it throws a compressor on it once i leave the patch..
            Jun 27, 43450
            Mar 5, 2012 4:47 AM (in response to PaulBateman)
            That's interesting ....  no, I don't think I can easily account for that
              Mar 19, 2010
              Mar 5, 2012 5:18 AM (in response to jimsreynolds)
              its very subtle... and not even an issue for me.... but thought i'd bring it up while we were on the subject...
              like the one guy above said.... load on the DSP could explain certain things... loading up a more extensive patch puts a load on it that could alter the tone in theory.. possibly the same effect the OP notices by filling up all blocks with "off" effects.. who knows.. lol... fun to discuss tho.. my pod has become my OCD object lately..
              i still suck when it comes to playing my guitar, but at least i can learn all the ins and outs of my gear... less frustrating haha
              (god..... just realized by my join date i've been playing for 2 years now....i shouldnt still suck this bad... haha... should spend less time tweaking and more time playing i think..)
              Message was edited by: PaulBateman
        Dec 13, 2007
        Mar 5, 2012 6:59 AM (in response to alfmetal70)
        fine, i'll record clips.  i'll do the delay off vs studio EQ off vs a blank slot and i'll compare the DT-XX switching parameters.  If I hear a change in the tone, I'll do the different mic selections when you are not in studio/direct output mode as well.  but i don't expect to hear any difference.
        i agree about the Master Knob clipping the input stage of a power amp (this happens on my combo amp), but as I said, it's not necessarily always going to be 60% - if people can set it higher without getting clipping, they should.  since it's in front an analog amplifier which will introduce noise into the signal, you want it set as high as possible to acheive the best SNR.
        Your impedance results are bizarre.  EMG advertizes that they're pickups use a lower impedance, which allows you to run longer stretches of cable with better SNR.  Thus, the impedance of the Pod should be higher than them even for lower settings, and the impedance settings should sound relatively the same.  For the passives, the opposite should happen - there should be a large change in the tone from 22k to 3.5M, getting brighter and tighter.  I'm going to record this as well, with actives and passives.
        at first i thought oh geez this guy figured out some very specific things here, but as it went on, some things seemed absolutely opposite of my experiences.  that's where my severe skepticism took over.  it's possible i'm wrong, or its possible that your pod is behaving strangely.  i'm happy to try to figure it out.  god help us all if you are right - it's gonna take much more effort to dial in the best patch possible if so.
        which firmware version are you using?
            Dec 13, 2007
            Mar 5, 2012 8:24 AM (in response to alfmetal70)
            i'm not angry or worried about my presets or anything.  i frequent this forum and try to help lots of people, and there's already quite a few myths floating around about the "secrets" to making the unit sound 1000% better and all this hooplah.  and the pod is already quite complicated with all the bells and whistles, not to mention a few quirks.  the things you are talking about go beyond the quirks i've discovered and would make dialing the full potential of the unit a quite time-consuming process.  that's why i hope you aren't right.  from a design perspective, it makes no sense why a lot of these things should matter at all.  i'd consider half of them bugs.
            i'm not trying to dog your opinions, such as with input impedance selections, or the amount of gain you like to use.  but when you are making positive statements that i don't believe are correct, I want others to know that I don't think they're correct before they end up wasting a whole lot of their time following a guide that does nothing to improve their tone.
            that being said, i'm not 100% sure i'm right - maybe you're spot on with at least some of your observations.  if so, i'll be glad to admit it and let others know that what you're saying is definitely true.
                Dec 13, 2007
                Mar 5, 2012 10:44 AM (in response to alfmetal70)
                i'll let the clips do my talking for me.  if you are correct, i'll apologize for being so assumptive.
                i'm only interested in determining if certain settings can make a tonal difference, not whether they improve or worsen the sound.  i'll leave it to each individual which tone they prefer.  but if there is no difference, i don't want people to spend time tweaking for no good reason or for potential buyers to be turned off because there's an absurd level of complexity involved in getting the best tone.  on the other hand, if there is a difference (that has no sensible design advantage/purpose), we should report this to Line 6 as a bug and badger them to fix it.
                I appreciate the level of detail you've put into your guide and your ambition to help others improve their tone.  i try to do the same thing.  I just don't want myths to snowball into assumed facts if they aren't true.
                As some examples, there was a myth that the tone from the HD300/400 was better than the 500/desktop/pro.  There is an ongoing myth that changing your Input 2 from Guitar to Variax improves the tone (which might be true depending on your patch, but only because it changes your input LEVEL not the input TONE).  There are various other myths, such as saying that turning up the Volume Knob on the amp gets you a "cranked amp tone" - this is one that you noticed is clearly false - it's more likely to push the tone into digital clipping.
                btw, i have my own guide: http://www.foobazaar.com/podhd/toneGuide/
                I'm sure I make recommendations that some might disagree with.  I'm also sure there's an error here or there and if someone points any out to me, I'm happy to correct it.
                    Dec 13, 2007
                    Mar 5, 2012 2:17 PM (in response to alfmetal70)
                    dude, don't get offended.  i think you've got the wrong idea about me and my motives here.
                    as i said in all my posts today, you might be right about a number of these things, and I'm going to record clips and we can all weigh in on them - maybe some people will hear a difference while others don't, maybe there's a noticeably apparent difference that everyone can hear.  then people can decide for themselves whether they should take the extra time to follow some of your guidelines or it's not worth their time.  if people want to follow your advice, that's fine with me.  i might be one of these people, depending on the results of my test later.  but if i don't think it's worth my time whereas someone else does, i have no problem with that.  if your guide leads me to improve my tone, I will thank you verbosely for preparing and uploading your guide.
                    the more time people spend tweaking their pod to no avail, the less time they spend on this forum, writing and performing or recording music, or dialing in solid tones that they can share.  that's depriving others of shared experiences.  if i can do 1 hour of research to free up hundreds of hours of other people's time, i'm glad to do it.  i will likely get a lot back in return.  it has NOTHING to do with me being some kind of power junkie that wants to dictate what people can and can't do with their gear.  it has to do with me being a good community member.
                    i want other people to buy pods to improve the support (ie firmware updates) line 6 provides for them and to get better patches from other users.  a lot of my approach to dialing in tones has come from good ideas and patches posted by others.
  • gortur Just Startin' 38 posts since
    Sep 19, 43371
    Mar 5, 2012 11:52 PM (in response to alfmetal70)
    I completely agree with meambobbo. I too would like to emphasize:
    - DO try different gain settings other than 100%
    - DO try different settings on the eq knobs
    - DO set the master knob to other values than 60%, depending on your amp, output mode and cabling
    - DON'T put in a whole bunch of disabled effect blocks
    - DO use ch. volume settings other than 25%
    - DON'T bother with mic settings unless you're using studio/direct mode
    - DON'T bother with DT settings unless you're using a DT amp
    There are enough considerations already using the HD500, so place your efforts where they belong.
      Dec 13, 2007
      Mar 6, 2012 7:15 AM (in response to alfmetal70)
      So it's safe to assume that no one hears any difference in the 3 clips I posted?
      Looking at the 4 patches, I'm not entirely sure but I think some of the tonal differences could be due to the signal having different volume levels because of how it gets routed.  REMEMBER - each line represents a stereo signal, and input 1 feeds into the left side while input 2 feeds into the right side of the first line in the signal.  at the split, the left half is routed to channel A, while the right right half is routed to channel B.  Both signals are then doubled into full left/right signals before hitting any amp/effects blocks.
      Here's a detailed description and some diagrams to help:
      http://foobazaar.com/podhd/toneGuide/setup#routing
      As for your patches:
      In patch 1 the tube drive is after the split (inside).  at the split, the input 1 side of the signal is being doubled as it feeds into channel A (the top path), so the tube drive is being hit with double the signal level as in patch 2 when it's in front the split (outside) where half the signal is Input 1 and the other half is nothing.  So patch 1 should have the most distortion of all these patches, which would show up as additional frequencies, as you put it.
      I believe 2, 3, and 4 should sound the same.  I cannot explain why they would sound different.
      This is a pretty "extreme" patch IMO - you have a heavily overdriven tube drive into a Rectifier with 100% drive.  It's possible that it is more sensitive to very small changes in the tone, but given that the Pod does this all digitally, it would have to be a bug, especially 3 vs. 4.  2 vs. 3 could possibly be explained in subtle differences in how the signal is mixed/split after a mono effect vs at the patch split.
      I did have some old patches that made my Pod do weird things - I tried to make a patch that was completely bass heavy and with a LOT of drive.  It seemed to create some kind of internal feedback issue, where I'd get this swelling droning sound when I played some palm mutes.  Maybe that's what's going on here - some internal component "doesn't like" your patch.
      Turn the tube drive's drive down to 10% and turn the Treadplate drive down to 60%.  See if you still get the tonal differences.  This will at least tell you if it's patch specific or possibly an issue with your unit.
      I'm not going to record more clips, but I will try the patches out tonight and let you know if I perceive any differences.  I'll try both direct and through an amp.
      But I don't think this has anything to do with going out to a real amp.  Those settings change the digital tone - it should be impossible for those settings to interact with the D > A converter or the analog Master amplifier, although I often wonder if the modelling is 100% digital or it uses the digital in combination with controlling some analog components.
          Dec 13, 2007
          Mar 6, 2012 10:08 AM (in response to alfmetal70)
          i'll give it a run and let you know.
          as far as the EMG height, that's a bit strange.  EMG's have very weak magnets, and EMG recommends setting them quite high (near the strings) relative to standard passive pickups.  Because they have a weak magnet you do not get pole pull and such that hurts the tone as with your average passive pickups.
          I understand the sentiment though.  Actives are a strange beast and seem to tend to compress the tone.  They seem more dynamic at lower heights, but they also tend to lose some frequencies.  I use Blackouts and I find the height really affects the tone and response, and I have a difficult time finding the exact position where I want them.
          Also, if you are running a pedal before the Pod input, the input impedance settings don't work as I describe.  I believe passive guitar pickups operate on a fluctuating voltage and variable impedance (reaching quite high), whereas active electronics (and pickups) use a static voltage and lower fixed impedance.
          It may be preferable to match the output impedance of whatever pedal you're using rather than using high Z settings, which could explain your experience.
              Dec 13, 2007
              Mar 7, 2012 6:32 AM (in response to alfmetal70)
              ok, i ran the 4 patches through my amp, and the results are as I anticipated.
              Patch 1 had a little more gain than the other 3, but the other 3 were identical to my ear.  I would try to A/B your unit to one in a store.  Also, have you updated your firmware up to the current version? (I'm actually one behind at 1.4)
              Is anyone else getting the same results as alfmetal70 with those patches?
                  Dec 13, 2007
                  Mar 7, 2012 6:32 PM (in response to alfmetal70)
                  when there's a pause between tones or a slight volume difference, people can start to believe there's a difference when there really isn't.  it happens to me all the time.  that's why i like to record and level volumes before doing a tone comparison.
                  i'm not saying that's what is happening to you.  seems obvious that you and others are definitely hearing an actual difference.  unfortunately i have no idea why.
                  you don't need to delete the guide.  there should be a link in the upper right of the page to edit the thread.  i'd just put a disclaimer in the thread that some of the suggestions in the guide might be specific to your unit or something strange with your software.  others might be having the same experience as you.
  • Floortom Just Startin' 5 posts since
    Sep 21, 2010
    Mar 6, 2012 7:27 PM (in response to alfmetal70)
    Appreciate the ideas alfmetal.
    I disagree with a few of your points but its always good to get more perspective
      Jun 27, 43450
      Mar 9, 2012 4:30 AM (in response to alfmetal70)
      Sounds like you are in much better shape now
      The Focus/Lows/Highs are indeed part of the configuraiton for the 'Front' modes.  There are no 'correct' settings as they are designed to cope with the tone of many different types of pre-amps.  You must use trial and error I'm afraid.  All real pre-amps will have a slightly different eq character.
      However ...  looking at your setup - direct into a power amp -  I think you may be better off using the 'Combo Power Amp' or 'Stack Power Amp' modes.   You have no 'real' pre-amp and the EQ on the 'Front' modes is there to compensate for real pre-amps.  You may not need this and front modes may a bad effect on your tones.
      Also, experiment with the 'Pre' amp models as (in conjunction with The Power amp output modes) they may sound better for your hookup.
          Dec 13, 2007
          Mar 9, 2012 7:14 AM (in response to alfmetal70)
          that's great news.  I think you see where I was coming from about eliminating unnecessary sources of tweaking.  With so much less to tweak, you can dial in patches much faster!
          I agree about the "front" mode.  Lots of people have been bugging Line 6 to give them a global EQ that applies to all patches, so they could quickly adjust the tone to a room (or different gear) and not have to edit every patch they use to get consistent results.  Well, the "front" modes give you a global EQ - it's not all-encompassing, but it can help.  The major issue with it is it is only available in two of the output modes.
          I find selecting a cab model which applies "live-voiced cabs" when not in Studio/Direct mode can also dampen some of the highs.  I prefer "no cab" because I like the highs, but it's another option to consider.
          Anyway, glad your unit is functioning normally and hope you can dial in tones even better than when it was acting goofy.
Bookmarked By (1)
